trip planner
Submitted: Monday, Nov 01, 2010 at 00:12
Member - John S (QLD)
does anyone know of a good web based trip planner for driving across Australia?
planning to do a trip from
Fremantle to
Cairns, the quickest way possible.
thanks,
Reply By: OzTroopie - Monday, Nov 01, 2010 at 00:54
Hi John,
Have you tried using Google Maps?
I just gave it a shot and the shortest route is 4,656 km, via the
Great Central Road. Looks like it takes you through Kalgoorlie,
Leonora,
Yulara,
Alice Springs,
Tennant Creek,
Gregory Downs,
Croydon, then East to
Cairns.
Obviously you'd have to check the suitability of roads for your rig and plan each leg and overnight stops.
A good road atlas may come in handy.
Others on this site may be able to give you other suggestions.
434732
Follow Up By: Member - John S (QLD) - Monday, Nov 01, 2010 at 01:06
thanks for that oztroopie,
i had considered that route, but then i heard that November is going to be too hot through the GCR, which is a real shame.
but i'll give google maps a shot.
thanks,
705822
Reply By: Motherhen - Monday, Nov 01, 2010 at 01:19
I refer to the one on
Go see Australia trip planner. It has choice of quickest (bitumen roads where possible) and shortest (incorporates all sorts of tracks and rural roads). It gives the kilometres and a time estimate. It also has the option to put one town as via to check options out. I don't use it as a trip planner, but it does give an idea of distances without spending ages adding up from maps.
434734
Follow Up By: Member - Oldbaz. NSW. - Monday, Nov 01, 2010 at 08:55
I'm with Motherhen on this one. I have just used goseeaustralia to outline a
forthcoming trip to Tassie & find it very useful..........oldbaz.
705832
Follow Up By: Member - Warwick D (SA) - Monday, Nov 01, 2010 at 11:04
Greetings Mother Hen, another great post, we will get you as PM yet. WD
705840
Reply By: Ozhumvee - Monday, Nov 01, 2010 at 10:01
Whereis works ok too, allowing multiple "via" points along the route.
I would also suggest that pretty anywhere is going to be hot at the proposed time of travel. If you keep speeds down below maximums, allow regular stops and possibly travel the "hotter/remote" sections either in the cooler parts of the day then all should be doable.
434746
