Roo Lite adjustment
Submitted: Monday, Nov 01, 2010 at 12:27
Member - Mfewster(SA)
Just had some 180 Roo lites fitted but the electrician discarded the instruction sheet. Just how adjustable is the spread on these lights? I note online that the beam can be adjusted by rotating the reflecors. Can this be done while the light is on so that you can see the effect? I'm not game to risk moving them when they are hot in case I blow something. There is a clip on the top of the lights but I can't get them to rotate easily and I'm not game to try to force the rotation too much. Any suggestions from those who have these lights?
Great beam though.
Reply By: Muntoo - Monday, Nov 01, 2010 at 16:06
If they are they are the same as Lightforce, which they are supposed to be, then you just unscrew the lens, anti clockwise. Might take a bit of effort to break the seal at first. Not worth it in my opinion, its just a useless feature as the lens will unscrew itself and will come off after a while. Its best to leave them done up tight in a spot pattern.
434770
Reply By: Tonyfish#58 - Monday, Nov 01, 2010 at 17:37
I have a set of these
1) At first hard to turn - once you have done it once it seems to be a lot easier.
2) They do adjust right down to a Spot beam, but not really needed at our highway speeds. I agree with above, more likely to undo if you do this.
3) I leave them wound right in which gives the full spread and found this ideal
4) Best way to adjust is
park 6 m from a wall on flat ground and turn on high beam. Measure up to the center of the beam & mark center of beam location L & R. Cover lights and turn on the spotties. Adjust height of spotties (set straight forward to match high beam level. Turn both spottie beams slightly out (L to the left, R to the right) say 6". Some people like crossing the beams, that is turning the R one to point L and L to point R.
5) Find a lonely stretch of road and
park. Turn on high beam and spotties. Cover headlights and see if you need to do a fine tune adjustment. If set on the wall I find this is not needed.
I have found on full spread beam that I can see
well into the distance and at 110k have no issues picking up
Cattle well in advance.
Cheers Tony.
434786
Follow Up By: Member - Mfewster(SA) - Monday, Nov 01, 2010 at 18:23
Hmm. Now I'm not sure which way to jump, but thanks Tony and Mintoo for the feedback. When facing the lights, which way should they be rotated? Both directions seem very stiff to me and I don't want to force them in the wrong direction.
705882
Follow Up By: Tonyfish#58 - Monday, Nov 01, 2010 at 18:33
To the left or Anti Clockwise
Cheers tony
705884
Reply By: Pete Jackman (SA) - Wednesday, Nov 03, 2010 at 15:18
Once you have them right, put a cable tie around the adjusting mechanism to hold the clip down tight - they will not unscrew then.
regards
Pete
434984
Follow Up By: Member - Mfewster(SA) - Wednesday, Nov 03, 2010 at 17:17
That's a useful idea Pete. Many thanks to you and the other contributors.
706080
