Adding a valve stem to alloy wheels
Submitted: Tuesday, Nov 02, 2010 at 15:40
geocacher (djcache)
Wondering if anyone has added a valve stem to a set of alloy rims?
Rims in question are GU Patrol series III rims. I want to add a valve stem for permanent mounting of tyre pressure sensors, while still having a valve for airing down & up.
Any thoughts? Advice on competent wheel joints in Vic (Gippsland or
Melbourne)?
Thanks,
Dave
Reply By: Member - mazcan - Tuesday, Nov 02, 2010 at 16:04
hi geocacher
interesting idea
some rims have reinforcement around the valve hole both steel and alloy
but the idea has merrit in respect to the fitment of tyre monitors
if the rim has extra strength built into it where the normal valve hole is then i would be very causous about drilling an extra hole as cracking could result
but if there isnt any reinforcement at the current valve hole then it may not create any problems to have the extra hole and in that case
i dont know if it is illegal to drill extra holes in a rim or whether it would void your insurance someone might know
i would put it exactly opposite the other valve to keep the balance in perspective that my thoughts on it if its legal to do so but its a curly one ?????
434862
Reply By: Ozrover - Tuesday, Nov 02, 2010 at 16:36
Hi Dave,
I've done this to all our steel
wheels after seeing a customers vehicle with a second set of valves in it, I personally wouldn't risk wrecking a set of alloy's (keep them good for resale) instead buy a set of good steel
wheels ie: ROH or similar & have them drilled by a competent fitter.
Definitely worth doing as it makes life so much easier when airing up & down as much as we do!
434866
Follow Up By: geocacher (djcache) - Tuesday, Nov 02, 2010 at 17:09
Small world Jeff.
I was there a week or so back when you were stuck in Alice. Talked to you when we were on the way out.
I've been considering the steel solution.
Thanks.
Dave #2
705961
Follow Up By: Ozrover - Wednesday, Nov 03, 2010 at 09:30
Dave,
Glad to hear that you got home ok, we stopped at New Crown for a visit & got back to Mt Dare that arvo' with no problems.
There was still a lot of
water about, but it's been driing up nicely since!
If you call ROH they sometimes have runout stock on special, I got the black rims on the 80 for $89 each, they are normally about $150, i'm keeping the GXL rims standard in case I have to change back to them!
706039
Reply By: ben_gv3 - Tuesday, Nov 02, 2010 at 17:32
If you do it yourself you can say goodbye to your insurance as it's an illegal mod according to the ADRs. You can however find some
places that'll do it for you. It then must be approved by an engineer.
You could also look at buying rims that can accommodate the Staun beadlocks that have 2 holes from the factory.
Either way it'll be a costly exercise.
434877
Follow Up By: geocacher (djcache) - Tuesday, Nov 02, 2010 at 21:24
Which ADR & exactly how is it illegal?
Dave
706002
Reply By: Member - Tezza Qld - Tuesday, Nov 02, 2010 at 19:42
What's wrong with fitting in tyre monitoring sensors ? I fitted a set to my GU ute and simply bought two extra sensors. One I fitted to the spare and the other is in the glovebox just in case I damage one on a tyre change. Every time I ajust tyre pressures , which is fairly regulary, I push the reset button and alls
well. On a GU steel wheel the valve stem fits close to the rim.
The only downside is the diameter of the airway through the valve stem is slightly smaller. In the bush to reseat the bead I simply remove the valve and use a short airline from the airtank to the valve.
Cheers Teza
434903
Follow Up By: geocacher (djcache) - Tuesday, Nov 02, 2010 at 21:27
Because I move them from front to trailer depending on what I'm doing or towing. With camper, two boat trailers, kayak trailer, other trailer it'd be an expensive exercise to fit them all up. And all trailers get towed long distances.
Dave
706003
Follow Up By: Member - Tezza Qld - Tuesday, Nov 02, 2010 at 22:14
Mmmmmmm I see your problem. When I enquired about drilling rims in
Brisbane I was told it was not legal hence the intyre monitors.
Personally I think drilling another valve stem hole and fitting a small stem such as of a quad for tyre monitors is a great idea but I suppose it depends on legalities. Wouldn't be to keen drilling an alloy rim though.
Cheers Teza
706008
Follow Up By: geocacher (djcache) - Tuesday, Nov 02, 2010 at 23:15
They drilled it to fit the original one. I'll pull a tyre off and have a look and see if it's beefed up around the stem.
We used to test
wheels for ADR compliance at Holden when I worked in the Engineering Instrumentation lab. When you see what they go through, another hole on the opposite side of the rim isn't going to make much difference - steel or alloy.
The only thing that buggered them after testing to several times their required RPM rating was the sledge hammer we put through the centre to stop people knocking them off out of the skip.
Dave
706016
