Mitsubishi Canter free wheel hubs
Submitted: Tuesday, Nov 02, 2010 at 18:11
Member - Des C (WA)
I have a Mitsy Canter 4x4 and am looking for assistance in servicing the free wheeling hubs. I have lost 4WD and am not sure if it is the hubs or axle which has failed.
Reply By: Member - Marc Luther B (WA) - Tuesday, Nov 02, 2010 at 18:52
Hi Des C
I don't want to throw a spanner in the works here so to speak, but I have used quite a few Canters, and frequently find the problem is neither, but a broken surclip in the locking hubs.
434887
Follow Up By: Member - Des C (WA) - Wednesday, Nov 03, 2010 at 12:09
Thanks for that Marc - I will check it out. Is the circlip accessable from the inner mounting (the one with the phillips head screws) or do I need to go in via the allen key bolts
Cheers Des
706057
Follow Up By: Member - Marc Luther B (WA) - Wednesday, Nov 03, 2010 at 18:19
Hi Des C
No seeing it myself I wouyld not assume to know which set up you have. I thiunk once you have a look yourself you will see if the surclip is fractured or not, I would be wrong to assert knowledge as to the structure when I have not seen your specific Canter.
Judging by your response, you have no doubt seen the physical structure, and should have no problem finding anything broken.
Good luck with it.
706089
Reply By: Member - Witchdoctor - Tuesday, Nov 02, 2010 at 19:55
Hi Des,
Have a look at
http://www.expeditionportal.com/
You will find loads of help in the
forum, particularly Whatcharterboat & Amesz00
David
434904
