air filter and charge light stays on after start- landcruiser hj 75
Submitted: Tuesday, Nov 02, 2010 at 21:01
ThreadID: 82266 Views:11198 Replies:5 FollowUps:5
Hi all
can anyone shed some light on this problem? Lights go off after 1200rpm then returns @ idle and there's a noise coming from something behind the glovebox.
Reply By: Member - Joe n Mel n kids (FNQ - Tuesday, Nov 02, 2010 at 21:54
jump on lcool.org and you most probally will get the answer you need, pull out the glove box as there are some electricial bits behind it, most probally a relay or something "buzzing" due to charge rate increasing at 1200rpm and low at idle...
AnswerID: 434920
Follow Up By: asbi - Tuesday, Nov 02, 2010 at 22:19
Cheers I'll do that,
FollowupID: 706010
Reply By: Member - peter f (VIC) - Tuesday, Nov 02, 2010 at 22:27
how long has it been since the alternator has been
reconditioned . check it with a volt meter on the battery
mechpete
AnswerID: 434923
Follow Up By: asbi - Tuesday, Nov 02, 2010 at 23:02
I'm hoping it's not that!
FollowupID: 706015
Reply By: Ruffy-Dan - Tuesday, Nov 02, 2010 at 22:58
Sounds like the charge rate is to low at idle. Increase in revs increaes alternator output. Filter light will come on due to shared earth circuits in the dash.
Check charge rate if you have an accurate volt meter, should be no less than 13.2volts.
Hope this helps.
Dan
AnswerID: 434927
Follow Up By: asbi - Wednesday, Nov 03, 2010 at 19:01
thanks for the info
Cheers Andre
FollowupID: 706094
Reply By: mike39 - Wednesday, Nov 03, 2010 at 08:39
The glowplug timer lives behind the glovebox, and it should certainly not buzz.
A faint "clunk" when it drops out is all you should hear.
If this is the 2h engine (hj75) the timer also has the low oil pressure cut out in there.
As suggested sounds more like an alternator problem but if you are lucky could also be a faulty earth, engine block to the battery negative.
What is showing on the voltmeter with the engine running? A few checks with a multimeter will help isolate the problem.
mike
AnswerID: 434947
Follow Up By: asbi - Wednesday, Nov 03, 2010 at 19:04
Hi All
Thank you for tips and advice? Volts were 12.7 now 13.7 @ idle.
It was a faulty earth but I will have alternator redone b4 the end of year as I haven't touched it in ten years.
THANKS AGAIN FOR ASSISTANCE
Cheers Andre
FollowupID: 706095
Reply By: Fab72 - Thursday, Nov 04, 2010 at 12:43
Voltage regulator.
AnswerID: 435054
Follow Up By: asbi - Thursday, Nov 04, 2010 at 17:21
Thanks getting it all professionally checked tomorrow- Cheers Andre
FollowupID: 706180
