Nissan Patrol injectors
Submitted: Wednesday, Nov 03, 2010 at 18:50
Member - Dino R (WA)
Got a mate who has a 03 Patrol 3 litre,he was saying he was quoted $600 each for a new injector by Nissan. Does any one know where you can buy cheaper ones or is it a lot cheaper to get his old ones serviced if possible. Cars running o.k. but will need to do something soon,cheers.
Reply By: Member - Bentaxle - Wednesday, Nov 03, 2010 at 19:02
Dino
Give
United Fuel Injector in Redcliff a call they may be able to advise.
Mike
| May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
Lifetime Member My Profile Send Message |
435002
Follow Up By: Member - Dino R (WA) - Wednesday, Nov 03, 2010 at 20:32
No worries will do then Mike cheers.
706110
Reply By: Muntoo - Wednesday, Nov 03, 2010 at 19:07
Is that 3 litre a common rail turbo diesel. If it is then that is probably right. The newer motors are around a $1000 each. Cant be serviced or reconditioned either.
435004
Follow Up By: Michael ( Moss Vale NSW) - Wednesday, Nov 03, 2010 at 19:45
I think the common rail engine was a little later than 03... i think!!!! Michael
706101
Reply By: TerraFirma - Wednesday, Nov 03, 2010 at 21:12
Normal mechanical injectors are serviceable, and repairable for around $200 each at most. Common rail injectors are not and are $600 + each
435020
Follow Up By: Member - Leon A (SA) - Wednesday, Nov 03, 2010 at 21:30
The early 3.0(non common rail) are not servicable either.
I would suggest speaking to Nissbits on patrol 4x4
forum.
706116
Follow Up By: Ianw - Wednesday, Nov 03, 2010 at 22:59
The ZD30 injectors are electronic & computer controlled , not mechanical.
Ian
706135
Follow Up By: GlennD - Thursday, Nov 04, 2010 at 00:47
03 injectors are mechanical , the fuel pump is controlled by the computer!!!
706141
Follow Up By: Ianw - Thursday, Nov 04, 2010 at 23:50
My apologies, you are correct. (Just read up on it in the manual)
Ian
706234
Reply By: Ianw - Wednesday, Nov 03, 2010 at 22:53
Reply By: B1B2 - Thursday, Nov 04, 2010 at 10:13
Dino,
Have you tried Hiflo Injectors, I just bought some for my LC 80.
Bill
435042
Reply By: Member - Dino R (WA) - Thursday, Nov 04, 2010 at 11:18
Some good info here thanks every one I'll check it all out cheers.
435045
