2" or 50.8mm square hollow section (SHS) Is it available in OZ??
Submitted: Wednesday, Nov 03, 2010 at 19:26
Michael ( Moss Vale NSW)
Gday All, Does anyone know if 2" SHS available in Australia. That is 2" or 50.8mm square x 3/16" or 1/4" wall section. All the square receiver hitches still seem to be 2" so the 50mm SHS that is available of the shelf is quite a rattling fit.. Michael
Reply By: Member - Ian F (WA) - Wednesday, Nov 03, 2010 at 20:18
G'Day Michael'
Check with Bluescope Steel they should be able to help.
Ian
435013
Follow Up By: Member - Ian F (WA) - Thursday, Nov 04, 2010 at 22:30
Unfortunately 50mm shs ( 1.6, 2, 2.5, 3, 4, 5 )mm wall thickness is only available in OZ.
Ian
706225
Reply By: Camkore - Thursday, Nov 04, 2010 at 13:43
Hi Michael,
You can use standard 50mm box section but you need to go up in the wall thickness.Made many of them myself being a boily just remember not to go to neat with the fit as dirt and mud can jam it up.On some tow bars they use small bolts to stop the rattle seems to work.
Cheers Camkore
435056
Reply By: cycadcenter - Thursday, Nov 04, 2010 at 15:22
Why not order a proper rated one from the USA. I'd be really worried about making one up not knowing just how strong it was.
Here is a link, with the Aussie dollar around parity you would land one in Oz for abt $80.00.
2" Hitch
Bruce
435060
Reply By: Camkore - Thursday, Nov 04, 2010 at 17:40
Hi michael
Oops just remembered your talkin about the hitch sorry. Most heavy duty hitches i've used (for the caravan) are made from solid square bar.They are certainly much heavier and sometimes require some grinding of the corners.Still the small 6mm bolts in the receiver seem to stop the rattle.
Cheers camkore
435070
Reply By: Michael ( Moss Vale NSW) - Thursday, Nov 04, 2010 at 18:00
Thanks guys... Michael
435073
