Tyre Pressure Monitors
Submitted: Thursday, Nov 04, 2010 at 11:11
Member - Noldi (WA)
Hi All,
I did a search on this subject and found some people had installed them of caravans and trailers in posts going back to 2008.
The price of tyres these days they seem to be a viable option if they work.
I was just wondering for those that have them fitted for a while, how have you found them for accuracy and reliability?
Also brand info would be good
Ian
Reply By: Member - The Crow (QLD) - Thursday, Nov 04, 2010 at 11:20
I have sensatyre on both my cruiser and van and have used them both for over 50000k in the last 3 years and found them to be great.
| 200 Series V8 Diesel
Thanks for the Rest Flying West and Flying Very Low along the track not coming back. The CrowLifetime Member My Profile My Blog Send Message |
435046
Follow Up By: Member - Noldi (WA) - Thursday, Nov 04, 2010 at 11:26
Thanks Crow,
I take it you have had no problems in that time are the sensors internal or the valve type?
I have also heard some say the temp reading are not accurate, is that your experience?
Can you set the low pressure alarm point?
Rgds
Ian
706156
Follow Up By: Member - The Crow (QLD) - Thursday, Nov 04, 2010 at 11:43
I have had no problems they are internal valve stem type you have to get a tyre fitter to fit them. They have been removed and refitted to 2 vans and 3 cruisers in the last 4 years without any dramas.
706158
Reply By: Member - Graham H (QLD) - Thursday, Nov 04, 2010 at 11:39
I have Securtire bought from China and have had them for two years
They are screw on valve type and are on both car and van.
Apart from batteries going flat they are OK. HAve done over 60,000k on all types of terrain on a round the block trip.
Depending on the van you may need a booster relay transmitterr.
I did on my Roadstar but dont need it on the new Coromal.
Pressure is relative Is ANY gauge completely accurate. Get 3 different ones and I guarantee they will differ.
Just use the sensors and check with another gauge and work out what you think is right.
I ran 36 front car 40 rear car 40 van ALL COLD IN THE MORNING pressures.
they built up 6 lb usually and temps stayed Ok.
Sunny side usually 3deg hotter than shady side.
Found a full width stone guard on the car sent rear tyre temps soaring so chucked it and temp dropped from 65 deg to 45 almost instantly.
Hope all that helps Cost of unit 10sensors and relay tranny was about $530
Saved me from crashing twice when lovely Dunlop tyres delaminated on van
435047
Follow Up By: Member - Noldi (WA) - Thursday, Nov 04, 2010 at 11:46
Thanks Graham,
I have a six wheeled bus plus I want to tow the Suzuki, hence 10 sensors would be ideal. I take your point about the guages, I have had several over the years and all been a bit over the place.
How long do you find the batteries last? are they easily available? do you change them your self?
Rgds
Ian
706161
Follow Up By: Member - Graham H (QLD) - Thursday, Nov 04, 2010 at 12:05
You can get extra sensors with unit and use them for spare as they "learn"
Batteries life varied and are expensive like $15 each here Bought them on Ebay for $1.50 each from USA They are lithium 2032 batteris changeable yourself.
706163
Follow Up By: Member - Noldi (WA) - Thursday, Nov 04, 2010 at 12:09
Thanks for the info, good idea about the batteries
706164
Follow Up By: Member - Warwick D (SA) - Thursday, Nov 04, 2010 at 17:26
Greetings, have TYREDOGS external sensors for 18 months, still trying to justify the cost. Like you the idea on my eight
wheels was great. I would not buy them again. The other brand seems to be doing much better. Those with US original sensors built into their imported cars are great, but they are not aftermarket.
WD
706181
Follow Up By: Member - Noldi (WA) - Thursday, Nov 04, 2010 at 17:31
Thanks for the feed back WD,
Is it a reliability issue
or just a cost V benifit issue?
Rgds
Ian
706182
Follow Up By: Member - barry F (NSW) - Thursday, Nov 04, 2010 at 17:40
You can buy the 2032 lithium batteries locally from
places like Battery World for about $2.50 each. It's twelve months since we purchased new ones for our monitors & from our experience they last about 12 months.
Somebody please correct me if I'm wrong, but when handling these little button batteries, avoid holding them between thumb & pointer finger,because I think it creates a short circuit & thus shortens the life of the battery?
706183
Follow Up By: Member - Noldi (WA) - Thursday, Nov 04, 2010 at 17:42
Thanks for the info Barry
Rgds
706184
Follow Up By: Member - Phil B (WA) - Thursday, Nov 04, 2010 at 19:54
Hi Noldi,
You firstly, I believe anyway, need to consider what type of driving you do. If its bitumen and you rarely let you tyres down, then maybe the valve cap types will do. If you're beach driving you'll soon tire of fiddling with them if you've fitted the locks, when airing down and then up. If you don’t fit the locks then there's the risk of having the senders pinched.
I do mostly severe off road desert travel, and lots of it off road i.e. no tracks at all. I have used both the valve cap type (Tyre Dog) and the internal type (SensaTyre) and found the internal type to be more serviceable i.e. they don’t fault as much because the valve stem isn't bouncing around due to the corros.
The SensaTyre model can be purchased to service up to about 12 or more tyres I seem to recall. Also there are two models of internal SensaTyre - I got the jubilee clamp around the rim model. The reason being if I need to repair the tyre in the bush there's less chance of damaging the sender.
In six months my SensaTyre set has already saved me three tyres ad paid for itself.
706203
Follow Up By: Member - Noldi (WA) - Friday, Nov 05, 2010 at 09:27
Thanks Phil,
What I have now is a bus soon to tow my suzuki so always on the tar/gravel.
But I already have lost a tyre and cracked a rim so I guess it would have paid for itself.
However I think for my application the valve cap type may be sufficient which I guess would be easy to install myself.
Thanks for the info
By the way since yesterday there are 2 others interested (one guy lost 2 tyres last year $400 each, ouch)
Rgds
ian
706257
Follow Up By: RoryW-Q - Tuesday, Nov 09, 2010 at 11:08
I've been using Tyre Dogs for about 18 months and have done all sorts of trips with them and think they are great. I have the 6 sensor unit (2 on my trailer) -In teh beginning i was constantly looking at teh unit but now - I find that I do not an initial check to see that all pressures are in the right place and then ignore the unit - it will give a warning if a tyre starts loosing air or exceeds (+or -)user settable thresholds for temperature and pressure.
706603
Reply By: MrBitchi (QLD) - Friday, Nov 05, 2010 at 10:32
There's a guy selling them on ebay for $189
Sensatyre on ebay
435117
Follow Up By: Member - Noldi (WA) - Friday, Nov 05, 2010 at 10:36
Thanks for the info MrB
706263
Reply By: Motherhen - Saturday, Nov 06, 2010 at 00:10
Has anyone tried these either in mechanical or LED as a cheaper alternative?
Tyre Checkers
Limitations include that once set for a certain pressure, they cannot be altered, and of course the need to watch for flashing lights (with LED) rather than have in car monitor.
435165
