SLA battery charging
Submitted: Friday, Nov 05, 2010 at 19:51
Member - Graham H (QLD)
Have two SLA batteries out of a computer UPS have been trying to charge them up with a little 1 amp charger
3 days later one is up to 7.5 volts.
Would it hurt to use my Ctek 7 amp on them.
They are 12v 17ah about the size of two bricks on edge.
Dont want to blow them up.
Reply By: Notso - Friday, Nov 05, 2010 at 19:54
Battery is beyond redemption.
435144
Reply By: Gone Bush (WA) - Friday, Nov 05, 2010 at 21:06
Unfortunately Graham, if you use a high amp charger they will end up looking like a football.
Reply number 2 above is correct.
435152
Follow Up By: Member - Graham H (QLD) - Friday, Nov 05, 2010 at 21:38
Thought that All my stuff has been stored for nearly two years so I guess they are cactus Cost a heap and I never really used them.
706304
Follow Up By: Member - Christopher P (NSW) - Friday, Nov 05, 2010 at 23:07
battery alsorts or battery world you can get them for 100 -130 dollars, and they are 20 amp's, look in the member company listings for batteries, there is a few who are members here!!!
ask them for a quote!!!!
no affiliation.....
chris
706307
Reply By: Member - Phil G (SA) - Saturday, Nov 06, 2010 at 20:17
Gday Graham,
You won't blow it up with a Ctek 7000. Its suitable for gels and batteries down to 14Ah.
If you hook it up, the Ctek analyses whether the battery can accept and retain the charge. I've used
mine on the occasional dead battery and if the lights flash then look it up in the manual to see what's going on.
Ctek manual.
I expect its probably dead!
435224
