crimping, help needed please
Submitted: Saturday, Nov 06, 2010 at 12:24
ThreadID: 82333 Views:3199 Replies:3 FollowUps:7
Hi All
Still working on my boat project, have managed to borrow and small and large set of crimpers. My question is with these joiners, do I insert the cable from both ends to the middle of the sleeve and then crimp either end? Why the slot in the middle?
Image Could Not Be Found
Lyndon
Now is the only time you own
Decide now what you will,
Place faith not in tomorrow
Reply By: Member - Fred B (NT) - Saturday, Nov 06, 2010 at 12:32
Hi Lyndon,
the slot is there to ensure you do do not bring your cable past the centre and that both ends are pushed to the centre to obtain a good join. You can crimp one end at a time.
regards
Fred B
VKS 737: Mobile/Selcall 1334
AnswerID: 435194
Follow Up By: Member - lyndon NT - Saturday, Nov 06, 2010 at 14:20
G'day Fred
Learn something new each day, thanks.
Lyndon
FollowupID: 706344
Reply By: Member - Joe n Mel n kids (FNQ - Saturday, Nov 06, 2010 at 14:34
Hi lyndon......
Few tips for "marine" wiring....
Use pre tinned wire, sold as "marine" wire, you may already be using it ...
After you crimp each join spray on some stuff called "Soft Seal" made by CRC, comes in a green tin, it will soak into the crimp and wire strands and seal out all saltwater intrusion, even if you heatshrink them spray it on first and shrink it on over it..
If you can solder each one helps and still spray em....
After you have got it all set up spray it all over every exposed electricial joint, spray on terminals, bases of relays, fuse boxes, back of switches .... anything metal....
Awsome stuff and will stop any corrosion from saltwater, be warned it washes off with ANY solvents so if you degrease your motor it will wash off, simply re-spray when dry .......... even coat the motor, mounts, bolts, hose clamps... you will thank yourself when you go to remove anything.
You may have seen some metal products that come with a "waxey" coating on them, the older outboards when new were coated in it, used to coat cars with it when it went on the boats.... that is the same stuff
Cheers (worked of pearl farm boats)
AnswerID: 435206
Follow Up By: Member - lyndon NT - Saturday, Nov 06, 2010 at 14:54
Thanks for the info, no I'm not using marine grade wire (already bought it) I am however about to go for a drive a get a can of soft seal!
Thanks for the tip!
Cheers Lyndon
FollowupID: 706347
Follow Up By: Member - lyndon NT - Saturday, Nov 06, 2010 at 15:13
AHHH, now you have thrown a spanner in the works! Where to buy in Darwin on a weekend?? Supercheap, Autobarn and repco don't have it???
The motor trade guys are all shut.
Anyone got an idea?
Thanks Lyndon
FollowupID: 706348
Follow Up By: Member - Joe n Mel n kids (FNQ - Saturday, Nov 06, 2010 at 17:22
Repco Winnellie "used" to stock it as that is where i got it from, back when "Monty" was there, sorry i dont know where else, i think CBC just up from Repco also had it (St Hwy)
It think Repco St Park also had it but that was 4 years ago, i now buy it from Repco in Mt Isa....
I think some Marine shops sell it, sorry eh cant be of much more help..
I have some here :-)
FollowupID: 706356
Follow Up By: Member - GeeTee (NT) - Sunday, Nov 07, 2010 at 09:54
Hi, Maybe try BCF.
I have a can but cant remember where I bought it.
FollowupID: 706392
Follow Up By: Member - lyndon NT - Sunday, Nov 07, 2010 at 10:52
Nope, BCF don't keep it either )-:
FollowupID: 706396
Reply By: Member - Stuart P (WA) - Sunday, Nov 07, 2010 at 01:34
the slot in the middle is so you can feed solder into the join
AnswerID: 435233
Follow Up By: Member - lyndon NT - Sunday, Nov 07, 2010 at 10:53
Makes sense, Thanks
FollowupID: 706397
