3' exhaust
Submitted: Saturday, Nov 06, 2010 at 20:10
Member - michael (BOXHD) r (VI
hi lookin at puttin a 3' exhaust on my nav 2.5 cr has any members had any thing to do with them and do they give u wht they say they do and which is best
cheers mick
Reply By: Monty - QLD - Saturday, Nov 06, 2010 at 22:02
I am looking for the same info mick must be somebody out there who knows
Monty
435227
Reply By: Muntoo - Sunday, Nov 07, 2010 at 02:30
Most exhaust specialists will telll you that a 3'' is too big for such a small engine. Its not required to have such a large diamatre exhaust, more a high flowing muffler and cat. A mandrel bend 2.5'' with high flow muffler and cat is all you need.
435234
Follow Up By: ben_gv3 - Monday, Nov 08, 2010 at 11:47
I thought that was the case for NA engines. I assume the Nav CRDi engine is turboed and hence already has enough back pressure (due to the wastegate) so a
milo tin-sized exhaust is OK.
706515
Follow Up By: Muntoo - Monday, Nov 08, 2010 at 22:42
A 2.5'' exhaust would be too big for a NA 2.5 litre.
It wont really add any benefits going with 3'' over 2.5'', and 2.5'' will be cheaper.
There are alot more to exhausts then just back pressure or diamater. A good exhaust is worth its weight in gold on any vehicle. Its just the costs can outweigh the benefits by a huge margin.
706569
Reply By: Patrol22 - Sunday, Nov 07, 2010 at 16:43
Guys you might like to do a search on the
Navara Forum - there has been quite a lot of discussion on this. Don't forget that the 2.5 CRDI engine is fitted to the D22 and D40 Navara and the Pathfinder since about 2005.
435272
Reply By: Wizard1 - Monday, Nov 08, 2010 at 11:39
Might be a silly question, but have you sought the advice of an exhaust specialist?
435326
Reply By: United Fuel Injection Pty Ltd - Monday, Nov 08, 2010 at 18:21
Performance gains are reasonable on the Navara 2.5, can i ask if it is automatic??
If so there is no real way of getting around the DPF hence most exhaust manufacturers are now not supporting the automatic vehicles.
435364
Reply By: Member - Mark G Gulmarrad - Monday, Nov 08, 2010 at 22:23
Mick.............i'm looking into one of these ones.
sterling
435409
