Whinding noise from the alternator
Submitted: Sunday, Nov 07, 2010 at 19:50
ThreadID: 82353 Views:2980 Replies:6 FollowUps:1
Got this noise coming from the alternator and both Batteries are low,so i reckon im up for a new alternator what do you think ? cheers GREENDOG
Reply By: Member - Stuart P (WA) - Sunday, Nov 07, 2010 at 20:20
is it a pitched whine or a growl, if it is a growling type noise it will be the alt
AnswerID: 435288
Follow Up By: Joe Grace Doomadgee - Monday, Nov 08, 2010 at 14:18
if it is a combination both ............ get the missus to hop out, drive around the block and if it has gone problem solved ...... nah just kidding LOL
FollowupID: 706525
Reply By: Member - Stephen L (Clare SA) - Sunday, Nov 07, 2010 at 20:21
Hi Pete
Take it to a good Auto Sparky, it may just need a good service. On our old Paj, the Brushes and bearing were replaced at the 100k mark with no problems at all and a lot cheaper than a new one. From memory it cost about the $110 mark.
AnswerID: 435289
Reply By: bert546 - Sunday, Nov 07, 2010 at 20:44
if it was a whining noise i mite be concerned. but saying that its a whinding noise i wouldnt be to worried.
AnswerID: 435292
Reply By: Member - Marc Luther B (WA) - Sunday, Nov 07, 2010 at 22:42
Hi Greendog
I regularly take both my alternator and starter motors out, clan the brushes with petrol and then leave them in the sun for a for hours to completely dry. I had a similar noise sometime ago from my alternator, and found that after a good clean it worked well again.
Probably a foolish question, but if your batteries are low, is the belt turning the alternator, first thing I would check, and if you are running through an isolator, is the isolator working as well. Just a couple of things to think about.
Why travel overseas, you could travel Australia your entire life, and not see it all.
AnswerID: 435302
Reply By: Honky - Monday, Nov 08, 2010 at 09:47
My work car is a new commodore and when the batteries are low ( had car fridge on went stopped ) it whistles which I assume is caused by the the extra load.
Actualy sound cool.
Honky
AnswerID: 435321
Reply By: Member - GREENDOG - Monday, Nov 08, 2010 at 20:56
Thanks guys for the feed back,it's in gettin fixed now,it was the Alternator.thanks again.G.D
AnswerID: 435389
