td42ti 2006 patrol misfire
Submitted: Sunday, Nov 07, 2010 at 20:54
Gobumpy
G,day all
Im new to
forum but chasing info on the td42ti diesel. my ute has 180000ks on it but at any rev above 1500 it has a miss and blows smoke a
grey colour was just wondering if anybody else has struck this problem if so what was the outcome. I am a diesel mechanic but mainly road transport and dont want to jump to worst case senario without first checking.
cheers all
Scott
Reply By: Peter E - Sunday, Nov 07, 2010 at 21:08
your getting air in the
fuel pump. It causes the timing to jump around.
Easy way to check, run a
fuel line from a jerry can straight into the injector pump. if it's gone check your filter system. They can suck air around the primer or the
water sensor in the bottom of the filter. If you still have the problem then it's the front seal in the injector pump. They have a 17 mm drive shaft and wear a groove in them. you can just replace the seal if you like or go for a full rebuild.
435296
Follow Up By: Gobumpy - Sunday, Nov 07, 2010 at 21:32
Cheers Peter ill check that out ill let you know how it goes
Scott
706475
Follow Up By: Member - joc45 (WA) - Sunday, Nov 07, 2010 at 22:39
I had trouble with my old GQ/Mav underpowered and blowing smoke under full load on the dyno. Changed the
fuel filter and all fixed. Apparently they don't like any
fuel restriction.
Worth a try before pulling off the injector pump.
Gerry
706480
Follow Up By: Gobumpy - Sunday, Nov 07, 2010 at 22:53
Cheers for that we have the filter didnt change problem will do more checks during the week will let you know
Scott
706485
Follow Up By: mike39 - Monday, Nov 08, 2010 at 07:42
I read somewhere that there is a small gauze filter where the
fuel line goes into the pump.
If blocked, can cause this problem.
May be a bum steer, but would be easy to check anyway.
mike
706503
Follow Up By: Dave(NSW) - Monday, Nov 08, 2010 at 08:34
I reckon Mike is on the money, It is a common problem on the 4.2s
Cheers Dave..
706504
Follow Up By: Member Bushy 04(VIC) - Monday, Nov 08, 2010 at 09:04
Had an identical problem with my 2.5tdi courier, it was the lint filter in the injector pump.
All that would happen is that at road speed it would get an intermittent miss,
mind you it took the mechanic about 30 min to pin it down.
Hope this helps Bushy.
706508
Reply By: Member - Bucky - Monday, Nov 08, 2010 at 07:19
Scott
Get it over to a Diesel specialist.
I just took our 2001 GU 11, to a specialist and the difference is very noticable.
160 k's on the clock
All injectors replaced.
Glow Plugs replaced.
Pump reset.
Dyno tuned
Goes much better, and
well worth it
Bucky
435310
Reply By: Member Bushy 04(VIC) - Monday, Nov 08, 2010 at 09:08
Had same problem with my 2.5tdi courier, intermittent miss at road speed.
The lint filter in the injector pump was the problem.
Hope this helps.
Bushy
435317
Reply By: MEMBER Bushbum - Monday, Nov 08, 2010 at 12:42
Scott I would definitely check the small gauze filter located below the banjo fitting on the inlet to the fuel pump. They do get blocked and cause a similar problem to which you describe. They don't get a mention in any of the prescribed
services and are also difficult to find on the Nissan microfiche for parts. I had a problem with
mine some years ago and told the mech that he should check the filter only to be advised there was none fitted. Persevered for a while but eventually had a look for myself and could only see a small spring in the aperture which I removed and had a bit of a prod around with a cotton bud and felt something shift so put a small amount of pressure on it, pulled it out and low and behold, a very dirty and blocked filter. Cleaned it and problem gone. From that time I have carried a spare in the glove box. Certainly worth a try and a cotton bud is a neat fit to remove it with.
Regards,
Ray W.
435331
Follow Up By: United Fuel Injection Pty Ltd - Monday, Nov 08, 2010 at 18:16
The TD42Ti's dont have the gauze filter, it could be an EGR problem or low transfer pressure in the pump rsulting in retarded timing.
706544
Follow Up By: MEMBER Bushbum - Tuesday, Nov 09, 2010 at 09:00
Sorry but you are wrong.
706586
Follow Up By: United Fuel Injection Pty Ltd - Tuesday, Nov 09, 2010 at 11:07
Ok ill leave it to the experts then ,i mean what would i know
706602
Follow Up By: garny - Friday, Nov 12, 2010 at 20:30
thanks for tip the gauze filter was as you explained cleand it and presto
has been smokin an under powered four a while me happy no smoke over the van
need to shout ypu a coldy
regards garny
esperance wa
707028
Reply By: Peter E - Monday, Nov 08, 2010 at 13:59
Mike is right> I forgot about the filter in the inlet. Not all have them.
Easy to tell if you have 1, Just remove the banjo bolt, if there is a spring then you have a filter.
Good luck
435339
Reply By: JR - Monday, Nov 08, 2010 at 14:20
2006 TD42ti dont have this filter under inlet fitting - or rather it exists but is located deep inside pump and unservicable
Check the basics as directed here then head to specialist
435340
Reply By: Gobumpy - Tuesday, Nov 09, 2010 at 01:22
Thankyou all for your advise been a great help we checked the pump inlet but no filter there ill be doing some more checks tomorrow checking for air leaks before an after pump if i cant find a problem it will be going to uniteds got some advise over the phone from them today. I will let all know what the outcome is.
Cheers all
Scott
435420
