waeco fridge plug
g'day there, I just bought a waeco which has the normal cigarette type plug, but the fridge slide in my camper has an anderson. Can anyone tell me if there is an adaptor or will i have to change the anderson
Reply By: Lucko - Monday, Nov 08, 2010 at 12:44
With my Waeco, I cut the cigarette lighter plug off and went for an Anderson. A far superior type of plug/socket in my experience.
Mark
AnswerID: 435332
Follow Up By: Member - Redbakk (WA) - Monday, Nov 08, 2010 at 14:07
I have 2 waeco's permanetly set up in the rear and I ditched the cigarette lighter plugs and swapped them for 50 amp anderson plugs years ago and had no trouble since no matter how rough the journey.
FollowupID: 706523
Follow Up By: Member - Redbakk (WA) - Monday, Nov 08, 2010 at 14:08
Oh....I totally agree with Mark.
FollowupID: 706524
Follow Up By: Allan B, Sunshine Coast, - Monday, Nov 08, 2010 at 14:19
I went even further. Cut the cigarette-lighter plug off and wired the Waeco flexible cable directly to the vehicle wiring. Bought a second Waeco cable/plug for use out of the vehicle. Andersons are good but not very elegant.
FollowupID: 706526
Follow Up By: Patrol22 - Monday, Nov 08, 2010 at 15:05
Like Allan B I've 'fix wired' my fridges in both the car and the camper......albeit they are Evakools.
FollowupID: 706531
Follow Up By: Lucko - Monday, Nov 08, 2010 at 16:05
Have to agree Allan B, Andersons aren't very elegant, however I find them very convenient. I have a 10M length of twin 6mm sq. cable with Andersons on either end. I use it to connect my fold-up solar panel, interconnect van house batteries to tug batteries if necessary and also for the air compressor. Both Waecos are connected in the back of the Patrol via a harness using Andersons, very easy to install and remove as required. I also have an Anderson wired to a pair of alligator clips in case I need to directly connect to a battery for any of the above.
Mark
FollowupID: 706533
Reply By: Andrew & Jen - Monday, Nov 08, 2010 at 16:12
My Waeco came with a Hella type plug with a cigarette plug adaptor fitted over the top. I just removed the adaptor and use the Hella, the latter being a very good positive action plug that fits all the female sockets on the van and 4wd. Given the low amperage of the Waeco, the Hella is more than adequate.
AnswerID: 435349
Reply By: p_marns - Monday, Nov 08, 2010 at 20:37
thanks everyone, i ll cut that plug off tomorrow and put on an anderson
AnswerID: 435383
