National Luna Battery Monitors
Submitted: Monday, Nov 08, 2010 at 20:20
pheonix
After discovering too late on cup weekend that my 2nd battery had died and my fridge would not work, I am wondering if anyone uses the National Luna duel battery monitor, and if so what are the liikes and dislikes. JUst trying to predict the future so the same thing does not happen again.
Graeme
Reply By: Rosss- Monday, Nov 08, 2010 at 20:51
Excellent unit, had one in my Patrol and now got one in the Colorado
435385
Follow Up By: Member - John Baas (WA) - Monday, Nov 08, 2010 at 21:19
Second that. Wouldn't be without it in remote country.
Cheers.
706556
Reply By: ABR - SIDEWINDER - Monday, Nov 08, 2010 at 21:09
Hi Graeme
What type of dual battery isolator do you have fitted ?
Many monitors are basic voltmeters and some have more features that work with the type of isolator you use. Also I suggest you have your isolator tested when you fit a new battery as it could be the cause of the problem, isolators do have a cycle life and will need replacing when the contacts start to deteriorate.
Derek from ABR
435391
Follow Up By: pheonix - Monday, Nov 08, 2010 at 21:49
Derek,
From memory it's the Redarc 12 v 100amp isolator. Too dark here in Melb at the moment to look properly.
Graeme
706563
Follow Up By: ABR - SIDEWINDER - Monday, Nov 08, 2010 at 21:59
When you have it up and running test the voltage on the input and output sides of the isolator. This voltage should be identical on a fully charged aux battery and no more than 0.3V lower on the output side on a discharged battery.
Notes: This is providing your battery cables are of a decent size, this test should be done with the engine running and hopefully with the alternator producing 13.8V or more.
PLEASE NOTE: ABR-SIDEWINDER no longer support, promote or sell Redarc products as we have been asked personally by the managent of Redarc not to do so.
706564
Reply By: greybeard - Tuesday, Nov 09, 2010 at 01:45
i use one of these
jaycar alternator tester
On my dual cab ute my 2nd batteyr is in the rear tub. I use some velcro and have this fitted to the window in the canopy so it is visible in my rear view mirror.
What i look for is to check if the battery isolator is working and the battery is beign charged when the engine is running. Then i check before I start the engine to see what state the battery is in. My triton has a volt meter for the primary battery allready in the dash.
It's cheap ( about $13 ), simple and reliable. If I'm bored I get my multi meter out and get a more accurate reading.
hth
435421
Follow Up By: greybeard - Tuesday, Nov 09, 2010 at 13:50
ps i'm a bit of a gadget nut but i've found over the years that I end up using the ok/possible problem monitoring solutions in preference to the expensive fancy toys.
If I'm travelling about the place I want my gear to work for me, not having me spend my time working for the gear.
I still use the fancy toys but only when needed.
ymmv
706618
