Tuesday, Nov 09, 2010 at 17:16
Re: Oldtrack123 follow-up
From my original post "happy for someone to correct me here but, I believe upwards of 6 - 8 amps 100% of the time"
First follow-up "Notso posted:
Mine draws about 10 amps and it is on all the time, no thermostat on the 12 volt system. "
Then followed by "Member - Captain (WA) posted:
But Carl, thats when running it draws the ~5 amps. As it cycles on/off, it will average out around 3 amps per hour, unlike a 3 way that draws a constant ~10 amps per hour with no cycling. "
As Evakool does not sell 3 way fridges I do not profess to know all there is to know about 3 way's, that is why I used the line in my original post to leave it open for people to correct (not attack) me.
Instead of someone advising me I was inncorrect in my statement, 2 people said they use more power than I stated and agreed they ran 100% of the time.
In the original question nothing was stated about gas, all that was mentioned was the amount of
battery power avalaible and solar panels to recharge. Therefore I assumed that the question was in relation to
battery power.
I agree that 3 way fridges, used in the right way, can be a very good thing on gas.
The main point I was making was that on electricity, of 2 comparable fridges, typically a 3 way fridge will use more than a compressor fridge in the same situation.
If, on the hand, Ian G in his original question had said he planned to run a T rated 3 way from
battery power only when driving and gas for the rest of the time, unless 240v was avaliable, I would not have needed to say anything because he had covered the main issues with 3 way fridges and therefore a long way along to being happy with his purchase.
706643
