Nissan GU - Electric brake controller
Submitted: Tuesday, Nov 09, 2010 at 21:36
ThreadID: 82398 Views:3239 Replies:5 FollowUps:0
Hi All,
Is there an owner out there with a GU 2003 Patrol that can advise which colour wire is the non-powered stoplight cable to splice ?
Jeff
Reply By: Ruffy-Dan - Tuesday, Nov 09, 2010 at 21:56
Gosh should remember... maybe red with yellow trace?.. or is that gq??? sorry.. can help tomorrow when i get to work.
Dan
AnswerID: 435507
Reply By: Member - Stuart K (WA) - Tuesday, Nov 09, 2010 at 22:49
G,day Jeff
Mine is spliced into the green with yellow trace.
Hope this helps.Also got the letter about the recall from nissan about the alloy wheel nuts today.Seems we get wheel nut locaters now.
Cheers Stuart.
AnswerID: 435513
Reply By: Member - Graham H (QLD) - Wednesday, Nov 10, 2010 at 11:00
If you are taking it off the brake light swich just stick a pin in each wire and get a multi meter and see which one is live.
Then hook it to the other one Thats what I did.
Also can do it in the loom that runs down L/H side can tap into it from front passengers side I think that one is G/Y from memory
AnswerID: 435552
Reply By: Member - Jeff (Luvmud)(NSW) - Friday, Nov 12, 2010 at 21:45
Thank you all for the replies.
I'll give this a crack tomorrow
Jeff
AnswerID: 435810
Reply By: KiwiAngler - Sunday, Nov 14, 2010 at 01:13
You may find this article of interest Electric Brake DIY guide
AnswerID: 435902
