Power Mate Jockey Wheel.
Submitted: Wednesday, Nov 10, 2010 at 21:20
sucrefoot
I have been given a "Power Mate Jockey wheel" with handle but it is only the complete wheel and ratchet including the handle. I do not have the jockey wheel bar to attach it to my caravan. It is over 20 years old and I am looking for the support pole to attach to the van so I can use it. Can anyone help?
Reply By: PradOz - Wednesday, Nov 10, 2010 at 21:30
Sounds like you need the clamp on the A frame to attach the jockey wheel to. You can buy them at most auto
places as
well as 4wd accessories plus BCF,
Supercheap, Rays Outdoors etc. You can bolt them on but i prefer to have them welded on.
Just be careful where you put it so that the ratchet handle works for the most of its range of movement. I find as close as possible to the hitch point but on the door side (footpath side) MOst ratchets i have seen will not work on the left hand side. I have not checked out your model though but am guessing its the same. Bracket will cost between $10 and $25 depending where you go
If you are stiill unsure just look at someone elses van to get an idea, even try the jockey wheel in theirs to check position if necessary, cheers
435607
