Tyre repair kits
Submitted: Thursday, Nov 11, 2010 at 12:30
ThreadID: 82432 Views:5779 Replies:15 FollowUps:11
I have finally changed over from tubed tyres to tubless ones after 10 years. Now when I had staked tyres in the passed I always had to remove the tyre and tube from the rim I would then repair the tyre by inserting the plug from the inside and then the tube as necessary.
So now that I run with Tubless tyres I will need to purchase a one of those fancy repair kits with the reamer thingo. I'm looking at the Bushranger Plugga II and the ARB equivalent.
The question is which one to buy or is there a better alternative???
regards.....................................jeff
Reply By: Member - Redbakk (WA) - Thursday, Nov 11, 2010 at 12:38
I've found these the besttyre repair
AnswerID: 435649
Follow Up By: Sand Man (SA) - Thursday, Nov 11, 2010 at 18:09
I also have a Safety Seal kit. These were (and possibly still are) the market leaders.
Excellent quality. Mine is three years old and still brand new:-)
The ARB kit should also be a quality one so it probably gets down to best price when you shop around.
As mentioned, avoid the cheaper kits with a plastic handle. They have been known to break and cause considerable damage to one's hand.
Bill.
Bill
FollowupID: 706880
Reply By: Member - Mark G Gulmarrad - Thursday, Nov 11, 2010 at 13:15
Jeff
do yourself a favour and buy decent quality ones.i bought the ARB ones which have a metal handle unlike the cheapies that have a plastic handle.
you'll expect to pay around $60 for the kit.
have used mine twice with no problems,cheers.
AnswerID: 435653
Reply By: Member - Stephen L (Clare SA) - Thursday, Nov 11, 2010 at 13:23
Hi Jeff
There are many brands and types out there on the market. My only advise is buy a good quality strong unit that will last a long time. I have the ARB unit prior to them putting their name to them. They are a strong unit and in the event that it is damaged, you can buy spares. I have seen of the cheaper units out there and I would not reply on them out in the bush.
Make sure you always carry lots of strings, as years ago one sidewall puncture required 3 strings in the one hole to stop it from leaking.
I have ours permanently in the vehicle and they are very easy to use.
AnswerID: 435655
Follow Up By: Member - Trouper (NSW) - Thursday, Nov 11, 2010 at 14:34
Yes I had thought of that re the extra strings and intend to buy additional quanity Thanks
Regards...................jeff
FollowupID: 706844
Reply By: ben_gv3 - Thursday, Nov 11, 2010 at 13:24
No need to spend $60 for the ARB kit.
You can buy metal-handled units for about $35. They might not have the extra hand guard handle bit like on the ARB ones but still do the job. I've used mine a few times and the only thing i don't like about it is the lack of the lube/glue stuff.
AnswerID: 435656
Follow Up By: Member - Mark G Gulmarrad - Thursday, Nov 11, 2010 at 13:40
short handle and no lube/glue?
reckon it might be worth the little extra will ALL the gear.
FollowupID: 706835
Follow Up By: Member - Mark G Gulmarrad - Thursday, Nov 11, 2010 at 13:42
.......sorry,meant to say extra handle guard.
FollowupID: 706836
Follow Up By: ben_gv3 - Thursday, Nov 11, 2010 at 14:15
The handle guard thing is a bit useless. I can plug tyres well enough without it.
I tend to use lots of lube to make it easier to insert so have run out and now bought more.
Incidently I carry mine in the car at all times and have use it on other peoples cars more then mine.
FollowupID: 706839
Reply By: Roughasguts - Thursday, Nov 11, 2010 at 13:44
I have busted a couple of the cheaper plastic handle reamers in the past.
But that's not a bad thing cause now you can stick the broken reamer in your cordless drill and make light work of reaming your next hole if it's in some tough tread.
AnswerID: 435663
Reply By: Member - Rodney B- Thursday, Nov 11, 2010 at 13:49
I've got the ARB unit and it works fine. I went to a Bridgestone tyre shop and they sold me industrial strenght glue in small can for the plugs. Works well and seals everytime.
AnswerID: 435664
Follow Up By: baza - Thursday, Nov 11, 2010 at 14:30
Hi Rod, I thought the ARB units were the same as the original Safety Seal one? They are self vulcanizing, so need no glue. I've used my Safety Seal kit many times on cars, ride on mowers etc, works great, no glue used. Cheers.
FollowupID: 706842
Reply By: Member - Trouper (NSW) - Thursday, Nov 11, 2010 at 14:38
Thanks Fellas appreciate the comments. I might go ARB
regards...................jeff
AnswerID: 435667
Reply By: Pete Jackman (SA) - Thursday, Nov 11, 2010 at 14:40
ARB unit here as well. Has not let me down yet.
Pete
AnswerID: 435668
Reply By: whisky_mac - Thursday, Nov 11, 2010 at 15:00
The ARB unit and the bushranger are made by the same people -
ARB. They just change the brand to keep the ARB exclusive.
I went for the Bushranger because I could not see the sense in paying for a plastic tyre gauge with the ARB one when you are going to have one on your pump which you will have to put air back in. I also prefer brass for my tyre gauges.
Jim
AnswerID: 435669
Reply By: Atta Boy Luther - Thursday, Nov 11, 2010 at 15:09
Tyre plugs are temporary , but lets pretend you forgot about the temporary lol . The safaty seal plugs actually vulcanise the rubber whereas the others dont . But remember that its just temporary . Try not to use the reamer unless you want to destoy the steel wires and possibly wreck the tyre . Start inflating the tyre to open up the puncture hole and then insert the plug .
AnswerID: 435671
Follow Up By: Member - Graham Watson (SA) - Friday, Nov 12, 2010 at 00:23
I recently got a tyre puncture which I repaired using the reamer and repair kit. The repair wasn't perfect but good enough to get us out of trouble when we shredded another tyre later. When I got back to Adelaide I took the tyre to get it repaired properly. I was told by the tyre shop they couldn't repair it because of the broken braid. Fortunately they had a second hand tyre the same as mine with almost exactly the same ammount of tread left which they sold me for only $10.00 more than the repair would have cost.
Graham Watson
FollowupID: 706934
Follow Up By: Member - Trouper (NSW) - Friday, Nov 12, 2010 at 10:20
Thanks for that info ATTABOY
FollowupID: 706970
Reply By: Member - Ed C (QLD) - Thursday, Nov 11, 2010 at 15:26
As far as the "string things" go, for value, it would be difficult to go past >>
this one here
I've had a similar kit for a while now, been used plenty of times, and the tools are plenty strong enough IMO..
The strings supplied with the kit that I have, look identical to those (extras) which I purchased from Rema Tip Top, so I have no issues with the quality of those either... (I've yet to have one leak)
As for the "self vulcanising" bit, I use Rema Tip Top Special Cement (blue) instead of lube, so that takes care of that ;-)
I also carry "proper" radial patches & mushroom plugs for those occasions when such may be appropriate....
Confucius say.....
AnswerID: 435677
Reply By: Rod W - Thursday, Nov 11, 2010 at 16:16
A tip - don't buy one that has a needle sharp point, as with them it is all too easy with them and they do create a new hole. Whereas the blunt pointed units follow the original puncture hole.
AnswerID: 435686
Reply By: Member -Dodger - Thursday, Nov 11, 2010 at 16:34
I have had the ARB kit for several years and have used it often (too darn often) and it is the best kit I have ever had.
Yep I had a cheaper version but the plastic handle broke.
In other words ye gits wot U pade fer.
Cheers Dodg.
AnswerID: 435689
Follow Up By: Member - Longtooth (SA) - Thursday, Nov 11, 2010 at 22:21
Rema Tip Top as mentioned several times above are the best available. Both my Rema Tip Top kits and a couple of spare bits all have plastic handles and haven't broken in 15 years.
FollowupID: 706922
Follow Up By: Member - Dennis P (Scotland) - Friday, Nov 12, 2010 at 09:23
Same here.
Rema Tip Top, every time.
Dennis
FollowupID: 706959
Reply By: Member - Bucky - Friday, Nov 12, 2010 at 09:45
Jeff
I use a Tyre Plyer kit, had it for years. used it 4 times in total.
last year, while I was setting up for our Canning trip, I went into the local Tyre-Power bloke, whom I buy my BFG's from, and got a tin of the industrial glue and patches & plugs they actually use
Also 2 tubes, that if I do not open the wrap, I can give them back.
Just good insurance, and to refresh my own stock.
Bucky
AnswerID: 435766
Follow Up By: Member - Trouper (NSW) - Friday, Nov 12, 2010 at 10:27
Thanks to all that replied.
Bucky I also have every concievable patch and really large plugs and I also bought glue from a tyre fitter, I dont trust those little tubes of glue,particularly if you break the seal and open them, then 2 months later its gone dry.
regards..........................jeff
FollowupID: 706971
Reply By: Ruffy-Dan - Saturday, Nov 13, 2010 at 00:16
The kit i have i would say is comparable to the ARB one in quality, but it also comes with a spare 'needle' for the aplicator should you break it. I never have though.
Also, with mullti pluigging, and don't try this at home kiddies, i once repaired a side wall stake with no less than 23 plugs. It was a case of have to and it worked, driving on it for another 3 hours to get us out of trouble.
Dan
AnswerID: 435820
