Wednesday, Nov 05, 2003 at 15:01
Slammin
In reply to your comments re tread lightly and 4WD v 2WD.
I must explain that at no time did I have any wheel spin during my dune crossing, I am merely pointing out that at the time I crossed
the desert the sand was firm enough that with tyre pressures set right and a sensible amount of momentum it was easy to traverse the dunes.
When ever I approached a dune that I felt needed a little extra I grabbed 4WD high on the fly just to assist with the climb, this was usually when the approach speed had to be reduced due to rough track conditions.
Only two things really help when climbing
sand dunes, "flotation" and "momentum" the extra traction gained when using 4WD is mainly required when there is a deficiency of the first two.
No Dunes were hurt during the making of this trip
Drifter...
In closing re the engine stress, i was conserving
fuel and for the main part the engine was coasting at around 1,500 rpm and doing it easily.
26186
