Towing a Jayco Finch with a Toyota Camry.
Submitted: Friday, Nov 12, 2010 at 16:46
ThreadID: 82452 Views:22016 Replies:6 FollowUps:4
Hi All, I'm new to the forum but have found much useful information already. Thank you.
Could anyone please advise if they have towed a Jayco Finch Camper Trailer with a 4cyl Camry (2009 model)? We are not planning to do any off-road travelling.
We would like to hire a Finch to test the car over a short trip, but we haven't been able to find one to hire in the Melbourne area.
Any advice would be much appreciated.
Thanks in advance,
Jessie
Reply By: Member - barry F (NSW) - Friday, Nov 12, 2010 at 17:16
Hi there Jessie, your vehicle manual should provide you with what towing capacity (weight ) your camry can legally tow.
The compliance plate on the Jayco Finch should provide you with its tare weight. Keep in mind the tare weight is the weight of the Finch when completely empty, no water in the tanks, no gas in the cylinders & no food, clothing etc.
So you will need to calculate the weight of all these bits & pieces & add it to your tare weight & then compare the Gross weight (fully loaded) with the towing capacity of your vehicle.
Best bet is to load it up & put it over a weigh bridge for accuracy & safety. If your Finch is capable of being towed by your Camry you will need to fit a transmission oil cooler. There is a good chance it already has one, if not, they are not expensive to have one fitted. Regardless, it is essential that the vehicle be fitted with one.
Being a front wheel drive vehicle, you should, in my opinion, also fit a weight distribution hitch. They are not cheap at about $600, but are well worth the expenditure, as they re-establish your steering geometry & braking capacity once the weight of your Finch ( ball weight) is a applied when you hook it up to your vehicle.
Good luck & happy travelling.
AnswerID: 435792
Follow Up By: Member - Graham H (QLD) - Friday, Nov 12, 2010 at 17:57
Respectfully the Tare is inconsequential
The ATM is the one you worry about and is in the cars handbook as the maximum amount the manufacturer recommends the vehicle tows.
The ATM is the maximum legally allowed weight on all wheels and the jockey wheel.
The GTM is the maximum legally allowed weight on the wheeels only and also should not be exceeded
The difference between the two should equate to your ball weight.
EG ATM 1500kg GTM 1350kg Ballweight 150kg
The car will also have a recommended maximum ball weight which as its front wheel drive should be observed.
As said a WDH will help and maybe Toyota will advise to fit upgraded towing suspension
The weight definitions above are the legal maximums BUT any van should be weighed as they definitely vary from whats on the plate depending on inclusions and extras.
Weigh it before buying.
FollowupID: 707005
Reply By: brizmatt - Friday, Nov 12, 2010 at 18:50
Towed a Finch with a 1993 Camry wagon (4 cyl manual) for a few years incuding Birs to Melb return and Bris to Daintree in summer return. From a motor transmissiion side it towed brilliantly- better than my 2010 Forester that I use niow but I did change cars as was towing about 10000ks per year and front wheel drive did not inspire confidence on gravel or in the wet.
I would do it, especially if plan to keep the Finch long term as when yiou next upgrade your car can get something more appropriate. Would first ensure that it meets all the specs and also would use a one bar WDH.
MattD
AnswerID: 435798
Reply By: Nanny24 - Friday, Nov 12, 2010 at 20:07
Thank you to Barry, Graham and Matt for their helpful replies.
As the tare weight of the camper trailer is given as 855kg and we are at present using a tent for camping, I don't believe the basic things we will add will exceed the 1200kg limit. The heaviest item will be the 82 litres of water.
We will check about the transmission oil cooler and we also plan to add a weight distribution hitch to our tow bar once we purchase the camper trailer.
Thanks, again, for the information provided.
Jessie
AnswerID: 435802
Reply By: wizzer73 - Friday, Nov 12, 2010 at 20:31
My father in law tows a jayco finch with his 4cy camry. Its a 2000 model with auto. He has done a half lap of australia with no problems. It does struggle a little on hills though. He does use a wdh as well which I think is a definate neccesity.
wizzer
AnswerID: 435805
Follow Up By: Nanny24 - Friday, Nov 12, 2010 at 20:37
Thank you Wizzer. That's helpful to know.
Jessie
FollowupID: 707029
Reply By: Member - DAZA (QLD) - Saturday, Nov 13, 2010 at 06:38
Don't forget that if it weighs over 750kgs you will require an Electric Brake Controler on the Towing Vehicle.
AnswerID: 435827
Follow Up By: Nanny24 - Saturday, Nov 13, 2010 at 15:16
Thank you Daza. We are arranging for that to be fitted as well.
Jessie
FollowupID: 707085
Reply By: Member - peter w2 (VIC) - Saturday, Nov 13, 2010 at 16:15
Hi Nanny24 I am towing a 650Kg 12ft van with a ford Courier Maxi,4 Cyl ,,, tows the van up hills with no problem ,,,, legally no brakes are required but I will soon be fitting elec. brakes to be on the safe side , Peter
AnswerID: 435871
Follow Up By: Nanny24 - Monday, Nov 15, 2010 at 20:37
Thank you, Peter.
FollowupID: 707285
