new tyres-fuel economy
Submitted: Wednesday, Nov 17, 2010 at 17:21
sfletch
bought a new set of tyres couple of weeks ago,hilux was going great / no probs good power / good
fuel economy...drive into tyre place car going
well - drive out . car going like bleep , new tyres Yokohama Geolander and wheel alignment ... now turbo is screaming .. hilux feels like i am towing a caravan up
hill and
fuel economy is out the window ...it is not my vehicle , hilux sreviced to a T.....it was as simple as it sounds....drive in / car good......drive out / car crap . thinking of getting wheel alignment re-done............
Reply By: Robin Miller - Wednesday, Nov 17, 2010 at 17:40
New tyres will improve economy if they are the same and account is made of the reduced diameter of old ones if worn and of course using same pressures.
But if you change to a lumpier / wider / type will get worse.
As your implying Sfletch , maybe your wheel alignment has been mucked up but it would have to be bad and soon visible.
Get a long piece of string and run it round car across all 4
wheels at once and look to see that both front and rear of your front tyres are just touching string at same time to indicate
wheels are pointing approx straight.
436246
Reply By: Lex M (Brisbane) - Wednesday, Nov 17, 2010 at 17:58
Are the replacement tyres the same size as the old ones?
436250
Reply By: Hairs & Fysh - Wednesday, Nov 17, 2010 at 18:42
Hi sfletch,
"...it is not my vehicle"
Did you check the NO Plate to make sure it was your Hilux?
Just kidding ;)
Are the tyre size the same as you had before?
"now turbo is screaming" So it's reving higher? means smaller Dia tyre.
"towing a caravan up
hill " sounds like a bigger Dia tyre
"thinking of getting wheel alignment re-done............"
I agree with Robin."to be bad and soon visible"
But this shouldn't effect revs or it's towing ability.
Hmmm, you've got a few dramas, hope you find the culprit.
Post back when you do find it please.
Cheers.
436256
Reply By: Member - Phil G (SA) - Wednesday, Nov 17, 2010 at 19:35
Sounds like the new tyres need more pressure.
436259
Follow Up By: Member - TonBon (NSW) - Thursday, Nov 18, 2010 at 07:32
I'm with you Phil, check tyre pressure. It's amazing what a difference 4psi can make, speaking from personal and similar experience.
707548
Reply By: splits - Wednesday, Nov 17, 2010 at 19:41
If the wheel alignment was causing that much difference, it would have to be so far out you could see it. You would not have to measure it.
I agree with those who have asked about tyre size. The standard size tyre on your car was most likely a 205 x 16, The diameter will be around 735 mm. All other factory option tyres will be so close to that diameter that it dosen't matter. If your new ones are much larger then the car will start to perform as you described. The larger the diameter the worse it will get.
436260
Follow Up By: Madfisher - Thursday, Nov 18, 2010 at 20:04
When we replace the standard 205s on our utes at work with geolanders they are always a bigger size. I feel this is where your problem is. By the way they are an excellent tyre.
Cheers Pete
707605
Reply By: SDG - Wednesday, Nov 17, 2010 at 21:53
I got a set of new Geolanders and found them to be good. None of the problems you described
436267
Reply By: fisho64 - Thursday, Nov 18, 2010 at 00:40
if the turbo is audibly "screaming",Id suggest there is something else wrong. Unless the tyre bloke accidentally did an alignment on the turbine "wheel" there is nothing he could do to make the turbo "scream".
436276
Reply By: sfletch - Friday, Nov 19, 2010 at 16:27
as i said...as simple as it sounds.....tyres are exact same diameter as previous tyres that they replaced....225/75/16 AT.......if anything these are less agressive than B F G which i had before....all i have done is walk in change tyres to exactly the same size as previous ones , get a wheel alignment and walk out......its like walking thru a door between good and bad....flicking a switch....... and it is that much noticable ... i dont understand it....i am at a loss to know why ?????? spoke to tyre place today they will check it next week . i dont think a couple of psi will make this much difference .
436372
Follow Up By: Hairs & Fysh - Friday, Nov 19, 2010 at 16:34
Hi sfletch,
Your right, a couple of psi would not make that much difference.
Bugger to have you vehicle running like that. When they do check it out, please post back as to what the problem was.
Cheers.
707657
Reply By: sfletch - Saturday, Nov 20, 2010 at 13:47
Did the string line thing....one side as straight as i could get it .... the other side pointing inward about 5mm .... dont know if that would be enough to make a big difference but guess if driving in a straight line both tyres could be pointing inward even if ever so slightly ??????
436454
