Replacing fuel filter
Submitted: Thursday, Nov 18, 2010 at 09:36
ThreadID: 82559 Views:3015 Replies:3 FollowUps:1
Hi ,
Can anyone give me a few clues on replacing the fuel filter on my 2007 CRD 3L turbo diesel?
I have done a search and not found anything.
Reply By: Member - dave e (QLD) - Thursday, Nov 18, 2010 at 10:38
how about some clues as to which vehicle
AnswerID: 436293
Follow Up By: Member - GeeTee (NT) - Thursday, Nov 18, 2010 at 11:13
Sorry about that...... Nissan Patrol
FollowupID: 707559
Reply By: Member - Marc Luther B (WA) - Thursday, Nov 18, 2010 at 12:21
Hi GeeTee
If your engine is not running, the fuel is not moving. If you make sure the brackets are tight, then using a oil filter clamp, twist the filter off and remove it. If you are putting a new fiulter on, make sure it is full od fuiel before you put it on, as that will save a heap of grief trying to get restarted and having air in the lines.
There are several sites that have manuals which can be downloaded, and are always helpful. Unfortunately I cannot insert links or open links at the moment.
Why travel overseas, you could travel Australia your entire life, and not see it all.
AnswerID: 436296
Reply By: rumpig - Thursday, Nov 18, 2010 at 18:25
