Pop top leakage prevention around stitching in canvas type material
Submitted: Sunday, Nov 21, 2010 at 09:43
Mineral1
Hi, first time post. Is there any product on the market that can be sprayed onto the exterior of the pop-top material to prevent
water seepage through the stitching on corners, and the plastic strips fitted into the material. Or is there a remedy that somebody has come up with I can use on our
Roma pop-top to keep it internally dry, other than living with the lid down while the rain is on .
Mineral
Reply By: Member - barry F (NSW) - Sunday, Nov 21, 2010 at 10:26
Good morning, I haven't an answer for you, however if you look up archived thread # 54080 you will find lot's of interesting info on the subject of repair & care of vinyl & canvas products. Good luck.
436518
Reply By: Member - Mark G Gulmarrad - Sunday, Nov 21, 2010 at 10:48
Mineral
is it new canvas or old?
if new you need to season it,by hosing the canvas down(paying more attention to the seam areas ) then let dry in the sunlight till dry.
the moisture swells the cotton seams and they dry that way.
hope this helps,cheers.
436521
Reply By: kiwicol - Sunday, Nov 21, 2010 at 13:54
I use a candle and run it a long the stitching inside and out, helps preserve the cotton and makes waterproof. cheers Col
436541
Follow Up By: Mineral1 - Sunday, Nov 21, 2010 at 14:41
Hi guys thanks for the help. The canvas/vinyl material isn't new, its 2003 model Van. Will look up the archive number given, thanks. The candle wax, now why didn't I think of that, top idea. :-)
707869
Reply By: disco driver - Sunday, Nov 21, 2010 at 15:34
Mineral,
I've used a Silicon pressure pack spray (supposed to be used to reduce friction on sliding doors and windows) on the seams of my poptop with some success.
Put the top up and then spray the seams externally. Leave it up for a while to allow the smell to disipate then pack it up as usual.
One spray has been effective for the 5 years that I've had this van
Disco.
436547
Reply By: Member - Bucky - Monday, Nov 22, 2010 at 04:37
Mineral
Bees wax may
well be the go.
Dry as a bone have a "retreatment" product with bees wax in it, and it works very
well. I did my vest not long after I brought it 5 or 6 years back, and it's still good.
Just go down to your local
camping store, or farm supplier, if you live in teh bush.
Failing that try Ray's tent City, or one of those type joints.
Bucky
436594
Reply By: Tony LEE - Sunday, Nov 28, 2010 at 14:16
I've used a product called Brellaproof. Australian made by canvas manufacturers. About $50 for 4 litres. Non silicone,
water based.
They say not to use it on brand new canvas but many years ago we bought a new poptop camper with the fold out beds - and first night it poured and all the bedding got soaked.
Used the brellaproof - coat inside and out - and we could have the bedding hard up against the canvas and it never got wet.
Recently bought an OKA with a Trayon type camper on the back. Similar thing although no where near as bad. Canvas is several years old and two coats of brellaproof mean we can sleep with bedding hard against the canvas. Not a drip gets through.
437149
