Load banging sound from the transmission?
Submitted: Tuesday, Nov 23, 2010 at 12:48
Steve P2
Hi I wondering if any one can advise me on something I experienced on the weekend.
I am relatively new to 4 wheel driving and bought an NP 3.5 petrol automatic a year ago and have done some day trips in it with no real problems. The car had 83k when I bought it and had never been off road. I have only done about 4k in it in the 12 months I have had it.
Yesterday I was going up the Strickland Spur track, a steep rocky track just out of Marysville.
I engaged locked low range at the start of the climb. I got about 100 metres up the the initial climb and had experienced a bit of slipping on the rocks when I heard a loud meteallic bag sound which appearred to come from underneath the middle of the car. It was different from the sounds being made by rocks being thrown up. I stopped the car and everthing seemed alright so I started to climb again. As I moved on there was another bang followed a second or so later by another bang.
I stopped again put the car in neutral and tried to disengage the central locking and move back into straight 4wd. The locking light stayed on so I rolled back in neutral a foot or two before re-engaging locked low.
I was then able to climb to the top of the track, which would have to be a couple of kilometres, and then back down the track without any further incident.
The only thing I can think of that may have caused the banging was that the central diff lock hadn't engaged properly even though I had already climbed a reasonable distance up the rocky track or some how it had partially disengaged.
Has anybody else experienced this situation and shed some light on it?
On a different issue, I was climbing Rocky track in Toolangi on Saturday. This track is steep and is loose rock. Again I had climbed about a 100 metres when first the flashing traction control light came on, followed by a beeping audible alarm that then changed to a permanent sounding alarm. I stopped the car and the alarm cleared. I presumed the alarm was sounding because I was experiencing wheel slippage on all
wheels.
Once I continue I got 20 to 30 metres further up the track where I lost traction trying to climb a small rock ledge. I rolled back a few feet in neutral and went back into drive. When I started to try and move the engine just free revved. I went back into neutral rolled back a few more feet and shifted back into dive. The transmission engaged and I was then able to continue my climb, albeit with the occasional audible alarm sounding.
Has anyone had any similar experiences in their Pajero?
Reply By: Member - Joe n Mel n kids (FNQ - Tuesday, Nov 23, 2010 at 18:45
hI there......... i wll explain what happened to us and "maybe" it may point you in the right direction.....
We had a ford courier, it started making a losd "bang" from the middle on the car but only in 4WD and under load....
The transfer case had a "chain" drive system, very good design, but we had a hole in the gear stick boot and a LOT of sand found its way into the transfer case and mixed with the oil and turned into a grinding paste, the chain system was only a short chain but about 2" wide and comprised of many links, with a TINY bit of wear in each link it all added up to about 2" streach in the whole chain and under heavy load would simply jump a cog .......
Have never worked on a Paj gearbox so i dont know if it uses the same system but i would start looking at that first.....
Cheers Buddy
Joe
436733
Reply By: Member - Marc Luther B (WA) - Wednesday, Nov 24, 2010 at 01:14
Hi Steve
It is of course totally up to you, but I would seriously be thinking about dropping the oil, checking it for metal shavings, and then if good enough, returnming the oil or putting new oil in.
If metal shaving a prsesnt, you are doing cog damage, which is what happened to a vehicle I helped with recently, though not a Pajero. You don't need a mechanic to do this, there is one bung plug under the gear box, and with a
hand pump you can replace the oil with the bung on the side of the gear box. You know that it is full when on a level surface, the oil reaches the lip of the side bung.
436779
Follow Up By: Steve P2 - Wednesday, Nov 24, 2010 at 08:52
Thanks Joe and Marc for your suggestions.
I will look further into it.
708189
