storage tips - water tanks advice please
Submitted: Tuesday, Nov 23, 2010 at 22:11
ThreadID: 82651 Views:3597 Replies:4 FollowUps:1
What is the best option for longer term, post trip, standing with regards to water tanks? Have a 120Lt tank on camper trailer (KK) with associated plumbing to various outlets and not sure what to do after the trip.
A) Fill it full to the brim and keep pressured to stop air in the system
B) Drain completely out
What's best? A) stops air and therefore mould, but B) could create stale water, over time.
What does everyone else do?
Thanks,
Graham
Reply By: Member. Rob M (QLD) - Tuesday, Nov 23, 2010 at 22:21
Graham,
I would usually leave the tanks full of water to eliminate air in the system and if the water tastes stale before the next trip, just empty and refill.
I am sure you will get other ideas.
Rob
Rob M
AnswerID: 436766
Reply By: Member - Josh (TAS) - Tuesday, Nov 23, 2010 at 22:24
I keep mine full. Occasionally I park it on the lawn and flush it through with fresh water. Best option is to use the camper often enough, it doesn't have time to go stale lol.
Josh
AnswerID: 436767
Follow Up By: Allan B, Sunshine Coast, - Tuesday, Nov 23, 2010 at 22:49
I leave mine with water in them and drain, flush and fill at the next trip.
Bear in mind that household water tanks can sit for many weeks with water in them and none being added. Not at recent times though!!!!!
FollowupID: 708163
Reply By: Member - mazcan - Tuesday, Nov 23, 2010 at 23:00
hi
zipdog
have a read of thread 79024
this has been discussed before
AnswerID: 436773
Reply By: Member - Kevin R (QLD) - Saturday, Nov 27, 2010 at 11:31
Hi Graham,
I have recently finished touring after 22 months on the road and have put my caravan into storage a few weeks ago with full water tanks. I have used a product called 'Waterpure' from Biomagic. In mid Feb we will begin touring again. I will leave with the same water in the tanks
Quote ....Waterpure is used to purify drinking water from microbial contamination in water tanks in caravans, motorhomes, boats and similar applications. Waterpure does not impart odour or taste to water, is non corrosive at in-use concentrations. It does not combine with organic material in water to form toxic compounds, as can occur with chlorine, and releases oxygen as it breaks down to further enhance water quality'... unquote
I use about 15ml per 82 litre water tank. The water will stay perfect for up to 12 months providing outside temp remains less than 50 deg C. This is for everyday use, not just for storage.
Have a look at the website www.BioMagic.com.au.
I hope that will answer your questions. I am very happy with the product.
Cheers KevinR
AnswerID: 437062
