Toyota Hi Lux
Submitted: Wednesday, Nov 24, 2010 at 18:28
ThreadID: 82666 Views:3072 Replies:5 FollowUps:3
How good or bad is the 4x4 hilux around 2003-2005, looking at towing a van around the 2400kg mark
Reply By: Dazmit - Wednesday, Nov 24, 2010 at 18:54
I think you will find that the Hilux only has a tow limit of 2100 or 2200kg as the 2005 only has a 2200kg limit.
Darryl
Brisbane
AnswerID: 436823
Reply By: Mark S (cns) - Wednesday, Nov 24, 2010 at 19:13
That model hilux is good (i.e the last of the old shape), but it is not adequate for 2400kg of van.
AnswerID: 436825
Reply By: Kimba10 - Wednesday, Nov 24, 2010 at 19:13
Depends on which model but neither will tow that weight. They changed shapes in 05, the old shape then changed to current shape. The old one was only around 1800kg the newer shape is around 2250kg. Might have to look at navara, triton ?? if you want a ute.The current ones are up around the 3t mark but not sure on the earlier models. Regards Steve M
AnswerID: 436826
Follow Up By: Member - Barry P (VIC) - Wednesday, Nov 24, 2010 at 19:53
have a 2003 turbo diesel sr5 rated too tow 1800 kg have towed a pop top van about 1100 to 1200 kg all up enough power but fuel consumption about 6 ks too the litre instead of usual 9ks too the litre on the highway bye barry
FollowupID: 708264
Reply By: Nev (TAS) - Wednesday, Nov 24, 2010 at 21:25
Hi winch nomads,
this guide is good although a little dated.
Site Link
No affiliation etc etc
AnswerID: 436845
Follow Up By: Nev (TAS) - Wednesday, Nov 24, 2010 at 21:31
And I forgot to add. I find the easiest way after the above chart is to Google say
toyota Hilux towing weight 2004
and it normally will come up with the weights. 1800kg in this case so 2400kg is illegal unfortunately. Have been through the same thing recently myself. The van I am having built has changed from a 2000kg tare to closer to 2700kg tare due to us changing our minds 50 zillion times. So my Jackaroo (max 2600kg) has been traded in on a Landcruiser (max 3500kg).
Hope this helps
FollowupID: 708282
Follow Up By: Nev (TAS) - Wednesday, Nov 24, 2010 at 21:32
oops Jackaroo 2500kg not 2600
FollowupID: 708284
Reply By: Ianw - Wednesday, Nov 24, 2010 at 21:47
Redbook is always good (for detailed specs of most vehicles)
2004 hilux dual cab 3.0l diesel
AnswerID: 436847
