road reports
Submitted: Thursday, Nov 25, 2010 at 11:43
Alloy c/t
A trap for the unwary , differing road reports from various sources can lead you into trouble , Currently in the centre of Qld many roads are closed due to the exceptional rain so far this month ,
An example of only listen to the local 1st hand knowledge is as follows ,
Yesterday 6am read RACQ road condition for Muttabrra to
Barcaldine to
Longreach , supposedly all open to all vehicles, at 7:45 am in real life
Lagoon Ck at .6m over the road and rising to a peak of .85m and close to 1klm wide,
Currently Racq report for
Muttaburra to
Longreach via the Cramsie rd states closed to all vehicles , err derr.
Local knowledge freely available at the shire websites updated constantly states different , 4wd ONLY from the
Muttaburra end and open all vehicles from the
Longreach end untill you hit the dirt.
Reply By: vk1dx - Thursday, Nov 25, 2010 at 13:16
This is an excellent example of a lot of things these days.
Firstly not a lot of "so-called" knowalls check all the evidence before putting up a report. Who would think of calling the local people. Nah Not enough time. And its not in my duty statement either!!! Or, I need to go for a latte.
Secondly: I am yet to find a website that is kept up to date. Many reasons for this and the main one is dedication to the customers you are serving. Need to knock off or get to the Cafe or go to a meeting first. Bugger the customers.
Cynical aren't I.
When we went up north we came across the same. So I elected to have alernatives and changed on the run as the roads and local people, rangers etc advised. Bramwell
Junction!!!!!. They (roadhouse staff) advised that Palm
Creek was too bad. But we thought we would have a look. Quite steep but basically a piece of cake. Even the locals can be wrong. That's why the alternatives.
436899
Reply By: Member - Old Girl (QLD) - Thursday, Nov 25, 2010 at 14:36
Well our boys were out in
the desert loading their tankers with oil and before they got the chance to finish down came three inches. A week later and the trucks are still stuck out there. So with so much isolated down pours even the locals are finding it hard to keep up. Remember its been 20 years since the middle of Aus has seen this sort of event so its hard to keep up. So yes the unwary only looking at lets say RACQ will most probably get caught out.
436904
Reply By: Member - Andrew (QLD) - Thursday, Nov 25, 2010 at 15:08
Road conditions in many of these areas are provided by the local Police guys updating the information when they are aware of changes. If the guys are out busy tending to on-road situations then this data may not be accurate as is acknowledged in the disclaimer that is ticked when accessing the webpage.
Having less staff than larger communities may mean that the information is not as timely as some expect.
Many Shire websites i have seen tend to be fairly static in their information, and any timely information for those travelling in the area probably comes down to 1 keen staff member who has time available to do the job :)
Andrew
436905
Follow Up By: Alloy c/t - Thursday, Nov 25, 2010 at 16:29
Out here the council gives the road status to the police who then pass that on to catcom and the RACQ ect , if you want the most upto date road report you need to call the local council road foreman , he / she is the one who decides if a road is open ,4wd only ,or closed.
708358
Reply By: Member - Marc Luther B (WA) - Thursday, Nov 25, 2010 at 16:44
Hi Alloy c/t
I can only comment from my perspective. We frequently contact the Shire of
Halls Creek and inform them of weather changes and road conditions. The Shire in all its wisdom usually then deems it necessary to send a vehicle out to find out about nthe conditions, and they rarely come more than 100 km out, we are 300km out from bitumen.
We have now decided it is not worth giving out weather and road conditions, as the Shire will always want to check, so they do their weekly run, and that becomes the latest update.
I know that many people in other communities don't bother anymore either, as too many bureaucrats don't seem to realise that the surrounding weather cannot be estimated by what they see out their window.
I have however told quite a few people not to travel the Tanami or the CSR at the moment, as the heat is rapidly building, and we are having 40 - 45 deg average days now. Heat "punctures" are becoming very common. We actually put a cold can of coke in the sand two days ago, and it burst after six minutes from the heat, so not the place to be at the moment if one isa not used to it.
436913
Follow Up By: Alloy c/t - Thursday, Nov 25, 2010 at 17:23
Yes , my point was to NOT only rely on road reports that are generally out of date even before they are put up on the web , we often end up with conflicting reports , 1 end of the road the
signage proclaiming open and the other end only 130klm away proclaiming closed or 4wd only , an hour out here in storm season the dirt can change from good to crapola with the "official" road report not updated for 24hrs or more.
708366
Follow Up By: Member - Marc Luther B (WA) - Thursday, Nov 25, 2010 at 17:40
Hi again Alloy c/t
I am in agreeance with you, as I am 300 km away from bitumen as
well, and half an hour can make the difference between reasonable and being bogged.
I referred to te heat at the moment as it causes so many problems that a lot of people do not even think about, ie, tyres over expanding. During the wet people who do not know these roads and the side tracks are
well advised not to even try.
708367
