Tyre pressures
Submitted: Friday, Nov 26, 2010 at 16:30
ThreadID: 82705 Views:4834 Replies:4 FollowUps:2
Related Pages
Hi Guys,
What tyre pressure should i be running (front and rear) on my 2009 Navara ST-R? I am towing a Jayco Swan.
Reply By: Notso - Friday, Nov 26, 2010 at 17:27
That info should be in your manual.
Otherwise talk to a tyre dealer.
AnswerID: 437008
Reply By: Mick O - Friday, Nov 26, 2010 at 18:22
Frank..
here's a search thread on the forum regarding tyre pressures
Pressure search
You should find a fair bit of info in there. Would also help if you indicated just what type of tyres your running, the tyre size and intended travel conditions (ie; bitumen, gravel, sand).
Mick
AnswerID: 437012
Reply By: OREJAP - Friday, Nov 26, 2010 at 20:25
There might be a tyre sticker near your driver's door (On the door pillar or vehicle body) tells you front & rear pressures also loaded pressures.
AnswerID: 437024
Reply By: landed eagle - Saturday, Nov 27, 2010 at 08:48
I tow a Jayco Expanda Outback with a Triton. Have 45psi all round the car and 48psi in the van. Doesn't feel as though I'm 'dragging' the rig around Aust. :)
Tyre wear is great. They've done nearly 20,000 kms and hardly show any wear .
AnswerID: 437054
Follow Up By: Member - Bill B1 (NSW) - Monday, Nov 29, 2010 at 00:35
I have a 2003 Prado Diesel with Duelers on 17 rims. I have done 25,000 km with 40 psi all round towing a 4.4 Windsor Rapid. Carrying a load also, in the back of the truck on Lovells HD standard height springs back and front.
I have not changed the pressures for the few dirt roads I have been on as they were a good surface generally. Not a fan of lower pressures for a stony surface anyway.
Have done sand lower, 20 psi, but that is all.
Good wear on all tires (have six; two spares that are rotated every 5,000 km).
Bill
Bill B
FollowupID: 708656
Follow Up By: Member - Bill B1 (NSW) - Monday, Nov 29, 2010 at 00:37
Whoops. Caravan are usual 15 inch with LT tires as supplied standard. I run 60 psi in them. No problems so far, touch wood.
Bill
Bill B
FollowupID: 708657
