How safe is YOUR van???
Submitted: Saturday, Nov 27, 2010 at 11:07
ThreadID: 82715 Views:4854 Replies:6 FollowUps:3
Hi All
Does your van have any of these FAULTS
The following links may be of interest in showing the good workmanship & quality control that goes in to many vans
http://caravanersforum.com/viewtopic.php?f=2&t=12286
This one on safety may also be of interest
http://caravanersforum.com/viewtopic.php?f=2&t=12338
Reply By: Nomadic Navara - Saturday, Nov 27, 2010 at 13:29
Whilst we are on bad workmanship, take a look at this one Numbers not bad for a small manufacturer?
AnswerID: 437066
Reply By: Member - Joe n Mel n kids (FNQ - Saturday, Nov 27, 2010 at 13:58
wow.... that WAS an interesting read, i will just continue on with the plan of building my own ..........
Why someone would pay $65,000 and ABOVE for a caravan still has me beat, this does explain it a little, people have the money to throw away and the market just cant keep up at the moment so as always in this situation corners are cut and money is made .... same ole story .......
AnswerID: 437068
Follow Up By: Member - mazcan - Saturday, Nov 27, 2010 at 14:53
hi joe n mel
yes have to agree with your comments lucky you can build your own there's nothing like it
good luck with it and at least you'll know it was done right
FollowupID: 708496
Follow Up By: Shaker - Saturday, Nov 27, 2010 at 18:33
Most people couldn't build their own, whereas you most likely couldn't remove a brain tumour!
I am about to take delivery of a Vista RV Crossover, apparently the prototype cost well in excess of 1 million dollars in R & D, this money has to be recovered.
FollowupID: 708507
Reply By: Member - mazcan - Saturday, Nov 27, 2010 at 14:49
hi all
very interesting reading and i would highly recommend it when you have some time as it takes a while but a real eye opener
these two topics reveal that we should be extremely wary of rv manufactures product and quality controls and even though they claim to have this
not only is this a problem for the initial buyer but also rings alarm bells for anyone who is buying second hand beware -beware of the pitfalls when shelling out your hard earned cash or borrowed money
quality controll it is reliant on the the human factor for a genuine inspection by a dedicated quality controller
who at the end of the day is probably only a payed employee and really doesen't give a hoot one way or the other
in lots of cases
and probably has more than one job to do and isn't watching every move during the construction period of each and every van on the premises
and relies on trust for the correct procedure to be carried out by each construction/assembler worker onsite
hence the result is all these bad faults in the caravaners/forum topics above
AnswerID: 437073
Reply By: Axle - Saturday, Nov 27, 2010 at 21:08
Its amazing really!!, .....What quality control is there?, apart from the same Doofers that are building the thing, She'll be right mate!!!, There needs to be a independant body that has to certify the construction in different stages, to help eleviate some of this shoddy workmanship!
Cheers Axle.
AnswerID: 437086
Reply By: bluefly - Saturday, Nov 27, 2010 at 22:28
Without naming the manufacturer of my camper van, he gets a big tick for involving me in the construction process. Nothing was too much trouble.
I came away feeling as though we manufactured the thing together. Perhaps there is a lesson to be learnt, rather than leaving things to chance.
I’ve found a bloke I can trust and he’ll get my business again.
AnswerID: 437090
Follow Up By: Member - mazcan - Sunday, Nov 28, 2010 at 14:27
hi bluefly
it would be an avantage to us all
if we all knew who this great caravan biuider is
why cant you share the so called lesson with us
FollowupID: 708571
Reply By: oldtrack123 - Monday, Nov 29, 2010 at 23:52
Hi All
Todays post by Cabcar is UNBELIEVABLE
:"The caption says it all - or almost all. The intelligentsia here attached the earth wires to the timber frame and not to any metal parts in the van. The chassis and the skin were not earthed at all."
Suggest ALL check it out ,then tell me if you feel safe in your van.
Below are my comments:
THAT is virtually CRIMINAL.
The Ba#*~ards should be shot & that includes the ar#* hole " licensed "electrical contractor?? who signed "OFF" after he did his through testing?
Yep I am Bloody angry
The most basic of tests is earth continuity @ all points .
That includes chassis & any conductive material within 100mm of any part of the 240v system[ window frames,door frames,metal skin,ETC]
When some one dies the authorities may wake up to just what is going on
AnswerID: 437345
