Pump for Longranger water tank
Submitted: Wednesday, Dec 01, 2010 at 16:56
ThreadID: 82796 Views:3049 Replies:1 FollowUps:2
I have a Longranger water tank under my 120 Prado. It is a real task to kneel down and grovel under the vehicle and turn on the tap. I was thinking of mounting a self priming 12 volt pump that will need to be above the lowest point of the tank water level. Will a self priming pump suck up the water say 300 mil above the water level in the tank? Has any one had experience with this situation ? Anything particular to look out for in purchasing a pump ?
Reply By: Mick O - Wednesday, Dec 01, 2010 at 17:22
No problems at all. They will lift it further than 30cm if need be. I have used a small pump to move water up from my 80 litre tank built into the tray of the ute. I would recommend that you use a Y junction or similar to plumb the pump in with and retain your manual tap as an emergency back-up should the 12 volt pump pack it in. There are plenty of pumps and options. Sure-flo and Flo-jet are the two most common brands around and available from caravan/RV supply places like Carac. Very easy to install, plumb and wire.
Cheers Mick
AnswerID: 437499
Follow Up By: Mick O - Wednesday, Dec 01, 2010 at 17:24
Oh yeah, another tip, whilst these pumps are pressure pumps and will turn off, make sure you wire them through a switch as well so you can turn them on and off manually at leisure. Saves a disaster should a tap come open accidently etc.
FollowupID: 709029
Follow Up By: Member - The old fellow - Thursday, Dec 02, 2010 at 10:59
Thanks Mick for your post. I can now go ahead and install the pump and tap and look forward to no longer having to crawl under the Prado !!.
Many thanks
FollowupID: 709147
