blocking off the EGR on a zd3lt
Submitted: Wednesday, Dec 01, 2010 at 22:57
ThreadID: 82805 Views:9127 Replies:5 FollowUps:7
I blocked off the Exhaust Gas Return and noticed the exhaust temp drops by approx 80c and my boost peaks a bit higher and tends to stay up longer.To my thinking this isn't right, any thoughts
Reply By: Member - Bucky - Thursday, Dec 02, 2010 at 03:39
carlj
Get your boost checked.
Apparently the ZD30 motors overboost, up to 30 psi is often the figure bandied aboout. 18 should be max
It can be adjusted to never go above that figure, but it is a specialists job.
Bucky
AnswerID: 437569
Reply By: Chaz - Thursday, Dec 02, 2010 at 05:08
Hi Carl,
Blocking the EGR will increase boost because you won’t have any escaping through the EGR valve into the exhaust. The ECU controls boost and EGR together to manage emissions so eliminating one will affect the other. The problem is that you will now see your boost drop off occasionally when the ECU lowers it to maximise EGR, which will bring your EGT’s up under moderate load conditions. The best way to overcome this is to fit a manual boost controller and bypass the ECU boost control solenoid. Many have done this with excellent results.
Chaz
AnswerID: 437570
Reply By: Mick O - Thursday, Dec 02, 2010 at 07:08
You might be better off trying the Patrol4x4 forum where this is a keen topic of discussion.
Cheers Mick
AnswerID: 437578
Reply By: Member - Bentaxle - Thursday, Dec 02, 2010 at 14:53
carlj
You are correct it isn't right, the moment you block off the EGR valve the turbo boost increases and you WILL blow your motor. You need to get the turbo boost reduced by someone who know what they are doing and also I would install a Dawes Valve (approx $280,well worth the investment) this will dump any overboost the turbo produces and will save an engine.
BTW I'm just in the process of replacing my engine as a result of turbo overboost - not a cheap excercise.
Mike
May the fleas of a thousand afghan camels infect the crutch of your enemy and may their arms be too short to scratch.
AnswerID: 437624
Follow Up By: On Patrol & TONI - Thursday, Dec 02, 2010 at 21:36
Sorry to hear about your engine Carl.
I hope you are not going to buy a ticket in the same (ZD30) lottery !!!!!
Colin.
FollowupID: 709229
Follow Up By: On Patrol & TONI - Thursday, Dec 02, 2010 at 21:38
oops sorry Mike
pays to be sober when replying
FollowupID: 709230
Follow Up By: Member - Bentaxle - Thursday, Dec 02, 2010 at 22:58
No wurries Col I came very close to following in your footsteps and built my own Toni
Mike
FollowupID: 709239
Follow Up By: Chaz - Friday, Dec 03, 2010 at 19:45
Bentaxle,
A Dawes valve is US$45 delivered to AU. I’ve fitted many with excellent results. It’s not a specialist job, all you need is a boost gauge to set it up.
Good quality needle valves are available from Dependable Distributors in Adelaide for $60 to complete the manual controller. It doesn’t dump overboost, but stops the turbo from producing it.
Dawes Valves available from 3barracing in the USA
http://www.3barracing.com/product_8.htm
Dependable Distributors http://www.dependabledistributors.com/ phone: (08) 8340 1222 and ask for TDi Needle Valve Kit.
All instructions to do the job HERE
Let me know if you need to know any more. chaz@conody.com
FollowupID: 709301
Follow Up By: carlj - Saturday, Dec 04, 2010 at 22:14
Chaz why would need a manual controller once you set the Dawes valve?
FollowupID: 709426
Follow Up By: carlj - Saturday, Dec 04, 2010 at 22:28
I know how you feel mine let go at 140000 hole in 3 and 4 cost me $10400 then 6 weeks later stripped 5th gear internal spline $1400 can't afford to get rid of it now but must admit it goes well now just get nervous on big trips but what can you do.
FollowupID: 709428
Follow Up By: Chaz - Saturday, Dec 04, 2010 at 22:57
Carl,
A Dawes TDi valve works much like a switch to stop boost at the level you set it at, but it can’t control your spool up rate. When you bypass the ECU boost control solenoid, you’ll put full vacuum to the turbo actuator which will cause your spooling to happen very fast and possibly get close to the surge area of the turbo. Turbo surge can destroy a turbo very quickly.
We call it a manual boost controller, but essentially it’s just the combination of a Dawes TDi valve and a small needle valve which we use to bleed off a small amount of vacuum to the turbo actuator, so that your spooling rate is reduced to an acceptable level.
By combining the two valves you can have full control of your turbo under any conditions that aren’t affected by the ECU and it’s strange characteristics. When set up correctly, your VNT turbo will work just like a conventional turbocharger and give you boost every time you use the throttle, not when the ECU decides you need it.
I use two Dawes valves to give me two different maximum boost levels. One is set at 10psi for low speed driving around town and good fuel consumption when I don’t need additional power. The other Dawes TDi valve is set to 15psi for towing, powering up hills and at high speed when my EGT’s start to get up a bit high. The needle valve is dash mounted so that I can vary the boost at any time, but I generally don’t need to do that once it’s set to give a good mid range spool rate.
This system gives me reasonable fuel consumption, all things considered around 12L/100k’s and I have 127hp at the rear wheels. I have gained power and my boost never exceeds 15psi, so the negine is under less stress and runs much cooler EGT’s as a result. Apart from replacing the turbo for a waste gate turbo like the Navara uses, this must be the best way to overcome the ZD30 Patrols inferior boost control system considering it can be done for just over $100.
FollowupID: 709431
Reply By: Member - warren G (VIC) - Thursday, Dec 02, 2010 at 17:57
went to do the same to my d40 after it back to a couple of times for faulty censers .when i unbolted the pipe a blocking plate fell out,not a hand made one but a pressed one that you would buy.my service guy didn't do it
AnswerID: 437640
