12v Sony Camera Battery Charging
Submitted: Thursday, Dec 02, 2010 at 17:27
Rod
I recently purchased a Sony HX5V digital still camera. As we all spend a fair bit of time out in the sticks, I want a way to charge the battery off 12V, without using an inverter and the supplied 240v charger.
Sony do not sell a 12V charger. You cannot charge the battery via the camera's USB port either.
Has anyone had personal experience in how to do this with "chipped" sony camera batteries. I have heard several reports of generic 12v camera battery chargers destroying Sony batteries. One
shop had one in stock, but when I mentioned I had a Sony camera, they would not sell it to me because of issues from past customers, limited to Sony batteries.
Anyone successfully charging Sony batteries off 12V ?
Reply By: Dust-Devil - Thursday, Dec 02, 2010 at 20:23
Rod.
You have answered your own question/s in your 2nd & 3rd paragraphs, in that Sony have gone out of their way to ensure that the charging method for their '12V' device (ie your camera) is from a 230/240V source via THEIR charging medium/device.
I try to never make assumptions, however in this case I have no doubt that Sony have incorporated specific electronic 'trickery/wizardry' in their charging device that makes it compatible with their so called '12V' battery and or camera if batterey charged whilst in same.
So you may find that you are restricted to the Inverter/ charger setup so that you don't fry their battery or if it charges whilst still in the camera - the camera along with the battery.
I use JAYCAR 150w 'drink can'
inverters whilst travelling to charge mobile phones and other devices, without any problems.
They are small and easy to monitor.
DD
437651
Reply By: ABR - SIDEWINDER - Thursday, Dec 02, 2010 at 20:49
I would recommend an inverter, you can use it for other uses and the Sony will work best that way.
Great camera, I bought one for my daughter and she loves the automatic panorama feature. It worked very
well on our Paris trip 2 months ago.
Derek
437653
Reply By: Lex M (Brisbane) - Thursday, Dec 02, 2010 at 21:37
Reply By: TerraFirma - Thursday, Dec 02, 2010 at 22:30
With all my cameras I have overcome this issue by purchasing 2nd or spare batteries to suit. 2 Batteries usually suffice. After market batteries for this camera start at $8. Do some shopping , spare batteries are worth their weight in gold for obvious reasons.
Some sample Ebay links.
Sony Batteries
437662
Reply By: Motherhen - Friday, Dec 03, 2010 at 00:36
Hi Rod
While my Sony takes AA batteries, in general i have found charging batteries on 12 v extremely slow compared to using a 240 v charger on an inverter. If they don't recommend it, why risk it? Two advantages of using an inverter to charge your camera.
437666
Reply By: Rod - Friday, Dec 03, 2010 at 09:54
Thanks for the replies all. It appears that no-one has successfully done this yet via 12V.
I dropped into a Sony store yesterday and they agreed that Sony were not particularly innovative in this area. Apparently you used to be able to charge some older Sony cameras via the USB, but Sony have disabled that feature and they were unsure why.
Both Sony and a couple of camera shops all agreed not to try generic 12V chargers. A salesperson in Teds had bought one of their own 12v chargers and had ruined batteries in her own Sony camera and they had other customers return also complaining about 12V chargers and ruined Sony batteries. Apparently it's the chip in the Sony battery that is unique to this brand.
Power wise, I am self sufficient via solar and 12V for fridge, lighting, laptop, mobile phone, UHF etc when I am away. Why should I have to lug an inefficient inverter around just to charge my Sony batteries ?
C'mon Sony, lift your game! You heard the market and let us use non-proprietry memory sticks in your cameras, now please give us a way to charge your batteries from 12V.
437687
Follow Up By: ABR - SIDEWINDER - Friday, Dec 03, 2010 at 11:22
Try this seller, I have bought from him and am happy with his products.
http://
shop.ebay.com.au/celltastic/m.html?_nkw=NP-BG1+Battery+For+Sony+&_sacat=0&_odkw=&_osacat=0&_trksid=p3911.c0.m270.l1313
709268
Follow Up By: ABR - SIDEWINDER - Friday, Dec 03, 2010 at 11:24
Direct-Link
709269
Follow Up By: Member - Barry P (VIC) - Friday, Dec 03, 2010 at 12:14
its worth a phone call to jaycar they have 12 volt chargers ;have too check with them if suitable for sony barry
709270
Follow Up By: TerraFirma - Friday, Dec 03, 2010 at 14:08
Rod, All the shops employ scare tactics toward aftermarket solutions. Do not fall for that. There is nothing wrong with quality generic solutions. You have been given plenty of good advise here, it's all easy, no need to complicate things down the Sony path. By the way Sony as a business are struggling, they were nearly bought by Apple recently, they are falling over in so many areas.
709281
Follow Up By: Lex M (Brisbane) - Friday, Dec 03, 2010 at 14:32
""chipped" sony camera batteries"
As far as I'm aware all Lithium Ion batteries are chipped to control charge and discharge so they don't burn or explode if incorrectly charged or mishandled
"Sony have gone out of their way to ensure that the charging method for their '12V' device (ie your camera) is from a 230/240V source via THEIR charging medium/device. "
Good to see that the conspiracy theorists are still active :-)
"Apparently you used to be able to charge some older Sony cameras via the USB"
Probably discontinued because charging any battery of any decent capacity is incredibly slow due to the low current limit on USB.
709284
