cast iron hotplates
Submitted: Monday, Nov 03, 2003 at 16:59
ThreadID: 8282 Views:1966 Replies:3 FollowUps:3
hi, i have receantly got a 2 burner cast iron BBQ hot plate and a cast iron sandwich maker and i was would like to know if anyone knows what to do before you use them to stop them from rusting?
Reply By: Member - Chris (Wollongong) - Monday, Nov 03, 2003 at 17:33
Give them a good scrub in hot water
Then heat them right up to burn off any bleep left over then coat in Vegetable oil and store.
AnswerID: 36087
Follow Up By: hoyks - Monday, Nov 03, 2003 at 19:46
cooking oil in a spray can works a treat. Easy to apply too.
FollowupID: 26031
Follow Up By: Member - Cocka - Tuesday, Nov 04, 2003 at 10:22
It's a good question and basically what Chris says is good advice. Take it a step further and use a wire brush then wash or dust off. Rub plenty of olive oil (it doesn't have to be the expensive EVOO stuff) or Sunflower seed oil into the surface then heat it up to high temp, this seasons the surface (it'll smoke like bug...ry) Re oil when it has cooled down. Later on after cooking, scrub with wire brush and lightly oil surface if storing for long period. Only ever wash lightly to remove soft food scaps. Don't scrape the surface, the carbon buildup is good.
Use good quality oils always.
FollowupID: 26065
Reply By: Member - Ross - Monday, Nov 03, 2003 at 19:30
Exactly as Chris says, but make sure you do it before the first time you use them or your tucker will taste like bleep because of the varnish or whatever they put on them at the foundry or where ever.
And when you heat them don't hold back ... make sure they're SMOKIN !!!!!Rosco
AnswerID: 36102
Reply By: Steve - Monday, Nov 03, 2003 at 22:33
Do all of the above ... unless Truckster says otherwise...
AnswerID: 36116
Follow Up By: Member - Eskimo - Tuesday, Nov 04, 2003 at 17:28
he should wait for truskster SteveWow! am I cute
If yer ain't fishing, Yer ain't livin
Richard
FollowupID: 26089
