Nissan patrol 2008 CRD ute gearbox issues - HELP please
Submitted: Saturday, Dec 04, 2010 at 11:16
ThreadID: 82842 Views:4949 Replies:6 FollowUps:2
My 2008 CRD patrol ute since new has had a lock out issue with 3rd & 4th gear whenever it gets hot, i.e I can drive 200 or 300km no problem then if I pull up for fuel or whatever when I start off again I cannot get 3rd or 4th gear at all, then after a few minutes of trying & cursing a lot, it works again for a short time but whilst hot the issue appears on & off at any time I change down gears. Once let cool overnight it is back to normal again until I drive distance.
Has anyone else had this issue & if so a fix would be very much appreciated as Nissan dont want to know, they have said it is fine & normal for the patrol boxes to be "notchy", I dont call this notchy it's outright dangerous....
Any help or hints would be great.
Reply By: Colcam42 - Saturday, Dec 04, 2010 at 11:31
Hi, since my Toyota had a 40000 service, the gearshift has been very "notchy", very difficult to change slickly into 2nd when cold. I believe that if they have put a "multigrade" oil in the box, it affects the friction of the synchro cones. ergo shift becomes erratic. Perhaps a drain and refill with the right specification oil might help.
Could be worth a try for your problem, what else can be affected by heat?
Anyone else any ideas?
AnswerID: 437789
Reply By: Gronk - Saturday, Dec 04, 2010 at 11:35
Get it nice and hot and ask for the workshop foreman to go for a drive ( with you in the passengers seat ) and see what he says to your face...
They usually aren't in a position to properly diagnose things unless it's playing up while they actually test drive it..
If the dealer still refuses to do anything, go higher !!
AnswerID: 437790
Reply By: Member - John T (Tamworth NSW) - Saturday, Dec 04, 2010 at 13:59
Hello GTB
I drive a 2009 Patrol c/chassis for work, have driven a couple of the earlier 3lt's as well for the same reason (2007 and 2008) and I have NEVER felt the the gearshift in any of them was as you describe - something wrong mate. As suggested, get it nice and hot and then get the service manager to drive with you riding shotgun.
Good luck with it.
John T (Lifetime Member)
VKS-737 Mobile 2619
Selcall 2619
AnswerID: 437802
Reply By: Dave(NSW) - Saturday, Dec 04, 2010 at 14:23
Maybe one of the guys on here might be able to help www.patrol4x4.com
Cheers Dave..
GU RULES!!
AnswerID: 437804
Follow Up By: got the bug - Saturday, Dec 04, 2010 at 14:55
Thanks Dave, I have just registered on patrol4x4 & posted the issue there too, we will see if any others have had the same problem.
Thanks,
Mark
FollowupID: 709396
Reply By: got the bug - Saturday, Dec 04, 2010 at 15:09
Thanks for the replies guys & yes the problem with Nissan is unless I can get it to them faulting they dont want to know. I have tried the long drive trick & taken it to a dealership in Perth as we live 4 hours drive from there & on arrival was told they could not look at it & could book me in for a weeks time......On making that booking & going up there the next week, it was a cool weather day & the fault did not show up, 8 hour drive round trip & dealership says no issue whats my problem !! Coincidently on the way home from the dealer & 3 hours out of Perth, due to the amount of run time I guess I had issues again.... no 3rd or 4th gear....Very frustrating...
I have queried the change oil & like the redline products although expensive seem to work however Nissan state if I change it then warranty is void & they will only use the same oil as is currently in it & have offered to change it for me for a mere $250 !! I dont feel this is warranted so back to square one...
I guess I just have to keep doing the Perth trip until it faults at the right time & go from there....
AnswerID: 437809
Follow Up By: Member - Graham H (QLD) - Saturday, Dec 04, 2010 at 16:13
Try making an appointment for them to take it for a drive.
They cant get out of it then I would think.
FollowupID: 709402
Reply By: Member Bushy 04(VIC) - Saturday, Dec 04, 2010 at 18:00
got the bug had a similar problem with my courier and it turned out be a g/box issue after towing in 5th gear.
hope this helps Bushy.
AnswerID: 437824
