Mapsource software ?
Submitted: Monday, Dec 06, 2010 at 12:12
ThreadID: 82884 Views:3585 Replies:4 FollowUps:4
Been give a Nuvi 1490T, and for the life of me I cannot load on Mapsource program.
Error massage, "no previous version".....
Ok I am no mug when it comes to installing stuff on computers.....
Everything is registered, and I have also got Aus & NZ Topo, in the Nuvi as well...Wow that is good.
But do you think I can get the "puter" to talk to the Nuvi
Can someone help me there ...
Much appreciated
Bucky
Reply By: Notso - Monday, Dec 06, 2010 at 12:44
Have a look here.
Full instructions.
Mapsource
AnswerID: 437979
Reply By: Member - Doug T (NT) - Monday, Dec 06, 2010 at 14:06
Bucky
What we need to know is....
where did the unit come from.
what type of Mapsource program your trying to upload into it.
If it's Garmin Topo then load it onto an SD card.
If you connect it to the PC and wait the PC should recognise after a few seconds
AnswerID: 437994
Follow Up By: Member - Bucky - Monday, Dec 06, 2010 at 18:35
Doug
The unit was a gift from my young fella.
He lives in Perth.
He updated to a newer one, and I got this one ..with current maps.
It is fully registered.
It's just mapsource, that I cannot load up..
But I will try Notso's method..
Keeping in mind that I have a fully installable disk of a very old Mapsource, I might get it back from a work collegue, that I gave it to, and then update it that way
Garmin Topo and City Streets are already loaded on a mini Sd card
Bucky
FollowupID: 709647
Follow Up By: Member - Doug T (NT) - Monday, Dec 06, 2010 at 20:38
Not sure what your trying to do but if it's trying to get the maps from the unit onto the PC....won't work.
FollowupID: 709665
Reply By: Bazooka - Monday, Dec 06, 2010 at 17:54
Bucky
The error message makes it sound like you have an update version of Mapsource, not the full install?
"If you have a device that has preloaded maps, and you have not purchased additional maps on DVD/CD, then you do not have MapSource. MapSource does not come with the purchase of a map download or a map on microSD™/SD™ card. It is only included with the purchase of a Garmin map on DVD/CD."
AnswerID: 438031
Follow Up By: Member - Bucky - Monday, Dec 06, 2010 at 18:37
Bazooka
You would be 100% correct !
But I have a way, just hope I can get back my old version of the installable one
Will know in 2 days, when I get it back..
Nothing else seems to work ( yet )
Bucky
FollowupID: 709649
Follow Up By: Notso - Monday, Dec 06, 2010 at 19:29
What Mapsource needs to find is the Install directory and a particular exe file, there are a couple of ways to do this and they are described on the link I added.
Extract for the site.
Here is an easy way to get Mapsource for free and legit. Here are 3 different ways to do it.
1. Download MapSource software updater from Garmin .
2. Extract the contents of MapSource_####.exe (such as MapSource_6156.exe) download using 7 Zip .
3. From the extracted files, run MAIN.msi or MSMAIN.msi.
4. Then, run Setup.exe.
Note: The sequence to execute Main.msi and then Setup.exe is important to avoid “Previous MapSource not found!” error.
5. Garmin MapSource now installed.
OR
1. Create a folder named Garmin on local C: drive.
2. Inside the C:\Garmin folder, create or rename a file as MapSource.exe.
3. Install the MapSouce by running downloaded MapSource installation executable, MapSoruce_####.exe (such as MapSource_6156.exe).
4. Garmin MapSource now installed
OR
1. First install the trainings center software.
http://www8.garmin.com/support/coll...ct=999-99999-04
2. This installs a basemap in the mapsource directory, now that the directory is there install the mapsource update http://www8.garmin.com/support/down...ails.jsp?id=209.
3. Garmin MapSource now installed
FollowupID: 709653
Reply By: Member - Bucky - Thursday, Dec 09, 2010 at 04:17
It's all good !
Installed, and looking forward to getting all my waypoints on it ..
Cheers for everyones help
Bucky
AnswerID: 438341
