ABS Light on - Toyota Land Cruiser
Submitted: Monday, Dec 06, 2010 at 13:00
ThreadID: 82885 Views:8948 Replies:4 FollowUps:3
I have a 2006 V8 Petrol Toyota LC the ABS light has come on, The mechanic at Toyota has looked at the errors and they are C0200 Right Front wheel speed sensor and C0215 Left Rear Wheel speed sensor. I am a little surprised that 2 sensors would have gone faulty. Would anyone know if there is an ABS module where all the sensors are linked back to?
On the weekend I will get the multimeter out and take some measurements.
Reply By: age - Monday, Dec 06, 2010 at 13:33
Hi Shaun
Had a similar problem with my Cruiser, but rear wheel only. It ended up that the Toyota mechanic was heavy handed when removing the spare wheel or whilst the vehicle was on the hoist at service time and stripped a wire from the ABS wire join block located just in front of the spare wheel. Might be worth a look. They were going to throw expensive new sensors etc on my vehicle until they looked closely and realised they had torn a wire out.
A
AnswerID: 437984
Reply By: TerraFirma - Monday, Dec 06, 2010 at 13:41
Check out these links on the code descriptions, can also be foreign matter on the sensors.
Site Link
Site Link
AnswerID: 437986
Follow Up By: Member - Shaun H (NSW) - Monday, Dec 06, 2010 at 15:56
Thanks for the info, once you find the fault will the light go out or will the computer need to be reset?
FollowupID: 709624
Follow Up By: Secret Mens Business - Monday, Dec 06, 2010 at 21:11
It should go out if it is a foreign matter issue, power issues or voltage issues can also cause it, my advice would be to see a Toyota dealer , would not be 2 x sensors but most likely one of the above, to reset the computer disconnect the battery for a couple of hours.
FollowupID: 709672
Reply By: Richard W (NSW) - Monday, Dec 06, 2010 at 18:48
Shaun,
I had a problem with my ABS light coming on in cold and wet weather only when I applied the brakes. Happened for about 2 weeks but then stopped and hasn't occurred again.
AnswerID: 438039
Reply By: ozzie4x4 - Monday, Dec 06, 2010 at 20:00
had the same issue on front right, took the sensor out cleaned it put back alls been good sinse
AnswerID: 438055
Follow Up By: Member - Barry P (VIC) - Monday, Dec 06, 2010 at 20:29
had the abs light on my hilux come on ;it was the the power supply to the brake lights broken ;as said before could be the sensors
FollowupID: 709662
