towing with auto gearbox
Submitted: Tuesday, Dec 07, 2010 at 21:43
ThreadID: 82921 Views:3617 Replies:3 FollowUps:7
Hi all just after a lil bit of advice with towing a camper trailer with an auto gear box. We own a 1999 GU patrol 4500 with an auto as its my first auto ever, was wondering if its like a 5 speed manual and shouldnt be using 5th. Should I have the OD mode off or not. The camper is not overly heavy and the big 6 pulls it great.
Any advice would be greatly appreciated
Scott n Lara
Reply By: Member - Graham H (QLD) - Tuesday, Dec 07, 2010 at 21:54
Have a read of thread 82799
all your questions have been answered there.
The Patrol forum will also probably help.
My advice is use 4th and the reasons are given in that thread.
AnswerID: 438174
Follow Up By: Gobumpy - Tuesday, Dec 07, 2010 at 22:14
I tried searching earlier but couldnt find what I was after only new to site will search thread 82799 now
FollowupID: 709798
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 07, 2010 at 22:35
Put preferences in the box at top of forum to "Show threads by response"
Change to show 100 on a page
Scroll down to see "Towing with a 5 speed gearbox"
FollowupID: 709805
Follow Up By: Gobumpy - Tuesday, Dec 07, 2010 at 22:48
Thanks Graham found it. Was an interesting read and now i can search for other questions now i know how.
Scott
FollowupID: 709810
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 07, 2010 at 22:53
When u do make sure if you dont find what u want click on show full results page and tick forum and untick all others.
That finds thread in the forum.
FollowupID: 709811
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 07, 2010 at 22:55
Thats if you dont know the thread no. and use the Search on the Toolbar
otherwise type in the box at the head of the Forum.
FollowupID: 709812
Reply By: Member - Bruce T (SA) - Tuesday, Dec 07, 2010 at 22:12
Hi Scott and Lara,
Have the OD off.
Bruce and Di
AnswerID: 438178
Follow Up By: Gobumpy - Tuesday, Dec 07, 2010 at 22:16
Thanks mate
FollowupID: 709799
Reply By: Outbacktourer - Tuesday, Dec 07, 2010 at 22:27
Had this box for many years behind a 3.0Di and did a lot of towing.
This box has a lock up torque converter that efferctively gives you direct drive when it is engaged. It will lock and un-lock depending on speed and load and is signalled by a 500rpm or so drop in revs on the tacho (but without a gear change).
The trick is to keep it locked.
I used to only use O/D when towing above 80 KPH under light load. At higher speeds, as soon as the lock came off (due to load) I would turn O/D off. In most circumstances it will lock again (in 3rd) at speeds over 80 KPH. At lower speeds on hills don't be afraid to manually pull 2nd, if you are above 60 it will almost certainly re-lock.
I had a temp gauge fitted to the tranny and can assure you that if you drive it right and keep it locked you will not have any heat problems, it is a good box.
OT
AnswerID: 438181
Follow Up By: Gobumpy - Tuesday, Dec 07, 2010 at 22:44
OT
Cheers mate thats pretty much how i have been driving it but as being new to autos just wanted to see if i was on the right track.
FollowupID: 709809
