Cappuchino makers
Submitted: Wednesday, Dec 08, 2010 at 07:48
Imanoone2u
Does anyone know of 12v or 24v cappuchino makers?
SHMO need a good coffee in the morning before making sense....
Cheers Marcel (The one who obeys)
Reply By: Member - Boo Boo (NSW) - Wednesday, Dec 08, 2010 at 08:22
Marcel
I have the same problem, and we have been looking for a year or so, but no luck.
438195
Reply By: Mick O - Wednesday, Dec 08, 2010 at 08:40
Plenty of 12V coffee machines about.
Coffee Machine Link
Thought of using an inverter to run a small AC powered machine? All a matter of how much you want to spend! I'm sure your piece of mind and the serenity of a
bush camp is worth any expense lol ;-)
Better you than me.
Cheers Mick
438200
Reply By: dereki - Wednesday, Dec 08, 2010 at 08:55
I am looking as
well, but want something light and small enough to carry in my backpack.
check out www.areopress.com.au or
http://presso.com/ or
http://www.handpresso.fr/
I am about to buy an aeropress (small light and cheap), they go for $50 and apparently make a good shot of espresso to put in your cappuchino.
Frothing the milk is a pain. I have a whisk like thing that you put in the cup and roll between your hands to spin it. Seems to work ok, but its not the same as steamed milk.
Sorry not quite what your after but might give some ideas.
D
438202
Reply By: MrBitchi (QLD) - Wednesday, Dec 08, 2010 at 08:58
Have a look at
this thread on this other
forum... Very entertaining and ongoing discussion about coffee and
camping ;-)
438203
Reply By: Shaker - Wednesday, Dec 08, 2010 at 10:08
We have one of these
BELLMAN , I know it isn't 12v or 24v, but it does work
well on the stove top.
438211
Follow Up By: Shaker - Wednesday, Dec 08, 2010 at 14:15
Forgot to mention, it also froths the milk!
709888
Follow Up By: Member - Leigh (Vic) - Wednesday, Dec 08, 2010 at 19:18
Got one too...just as good as the Gaggia at home but it takes a little longer and must follow the directions in the booklet re pressures etc. If you like good coffee this is the unit.
709953
Reply By: Robin Miller - Wednesday, Dec 08, 2010 at 10:16
Hi Marcel
Know of no 12v ones , have been dissapointed at the coffee even some of those $2000+ De-longi types around.
We have a genuine Italian no power item that would fit in a 2lt bucket.
http://www.atomiccoffeehouse.com/about.html
You just heat it on a gas stove and it makes coffee and produces quite a load of steam for frothing.
We don't use this anymore for
camping , to much trouble (I think it a classic now, probably worth a fortune)
Over a long period we have developed our own method - there are two key stages - the coffee liquid and then frothing up the top.
Out
camping I am happy enough to use those instant cappicino packets of which there is a variety with different tastes etc.
We use 1 packet per 150mm of 1/2 milk 1/2
water which heats better than milk. Some can be a bit sweet so you have to try a few till you find one you like and some friends even like to add a little instant coffee with it.
For the critical froth stage -
well we side stepped that and now always take a can of spray cream , just stick nozzle under surface of hot coffee mix and it froths up so
well its hard to believe. Liberal choc powder on top and off you go.
In fact its all now come up so good , and the alternatives even in some small towns are so unreliable that one finds oneself actually preferring to make ones own more and more.
438213
Follow Up By: Alloy c/t - Wednesday, Dec 08, 2010 at 11:29
Robin , saw a coffee machine collector on the ABC show 'collectors' ,a fair while ago though , he raved on and on about the atomic brand of machine , and he was paying a small fortune for them , might be worthwhile looking into !
709854
Follow Up By: Member -Pinko (NSW) - Wednesday, Dec 08, 2010 at 16:57
Hi Robin
We have had an Atomic for over 25 years.
I needed some new seals etc. and found Bon Trading had closed down. So no more Atomic coffee.
I clicked the web address you gave and I find that they are in business again.
This arvo I ordered the spares we need so we will be sipping coffee again.
The machine makes a great brew either esspresso or capuccino.
The two pot esspresso versions are no match for the atomic.
Stan
709917
Follow Up By: Robin Miller - Wednesday, Dec 08, 2010 at 20:58
Hi Guys
Thats good news Stan , great machine , and very entertaining as it blasts out steam under pressure as
I keep my Atomic around , its good to have some old stuff that lasts in amongst all the plastic we own these days , I think your right Alloy about the value ,
mine has to be 50 years old now and still goes
709989
Reply By: ExplorOz - David & Michelle - Wednesday, Dec 08, 2010 at 12:37
I symphathise with your wife - but just need the coffee, not the froth so we grind the beans using a normal 240v grinder attached to the invertor (few secs), then brew up using a stainless steel perculator on the gas cooker. Good strong proper coffee. However, I notice that Waeco Dometic now do a 12v cappuchino maker...
Good luck with it - Michelle
438228
Follow Up By: ExplorOz - David & Michelle - Wednesday, Dec 08, 2010 at 12:42
PS David has been threatening to invent a coffee machine that runs off the aircompressor... or the heat convertor we have under the bonnet that runs the shower...never enough time to turn all dreams into reality though. Some people obsess over their beer, then there's the coffee addicts !!
MM
709867
Follow Up By: Member - Russler - Wednesday, Dec 08, 2010 at 18:27
Anyone considered powering one off of a PTO? Probably be ground to dust in seconds though
709937
Reply By: Fab72 - Wednesday, Dec 08, 2010 at 12:48
...and I bet you're a happier man once she's had her coffee too.
I was faced with the same problem. I even went so far as to buy some 12V kettles..... all rubbish I might add, even the more expensive ones. Don't boil and take 30 minutes at best to even heat the
water.
In the end, I bought a Bush Kettle which I use to boil the
water off of a handful of dry leaves or even balled up newspaper.
Then I recommend Robert Timms coffee bags. Not quite the same as my $1700 DeLonghi but the closest you'll get to Perculated coffee in Instant form.
Try it...it's actually pretty good.
Fab.
438229
Follow Up By: Fab72 - Wednesday, Dec 08, 2010 at 12:50
Forgot to add.. we got the bigger of the two Bush Kettles, which works just fine. Just enough
water to make up 5 containers of Instant Noodles too.
Fab.
709871
Follow Up By: Fab72 - Wednesday, Dec 08, 2010 at 12:58
Again...not a 12V option but you can't beat these things for coffee if a fully automatic unit isn't around.....
Can get them from just about anywhere.....then you just need to work on the frothy milk.
Fab.
709874
Follow Up By: Member - Leigh (Vic) - Wednesday, Dec 08, 2010 at 19:23
Having married an Italian I have a house full of these and one resides in the draw of the vehicle at all times. Great for a quick short or long black and only a few minutes to make!! Highly recommended
709956
Reply By: Member - Paul B (WA) - Wednesday, Dec 08, 2010 at 18:52
What's wrong with a plunger?
438275
Reply By: Member - Amy G (QLD) - Wednesday, Dec 08, 2010 at 20:28
I make an italian espresso on the stove as pictured above, though I would looooooove a proper espresso when
camping! Yum!
For your milk, for less than $3 you can get one of these -
http://www.ikea.com/au/en/catalog/products/30191649
It's easy to heat up your milk, put in the frother for 15 seconds and you have froth for your cappuccino. Yum x 2!
438295
Reply By: Member - barbara M (NSW) - Wednesday, Dec 08, 2010 at 20:42
Hi Everyone,
I hope this helps dont drink coffee myself but our fiends do who travel with us they have a coffee machine that they use on their camper stove it makes a mooing sound when it is ready they and our other friends swear by it. They bought it at a specialist coffee
shop in our small town of Maclean in NSW I eetry to get the name of the machine. www.coffeeart.com.au I dont know how to do a link. The guy that runs this is a top barrista who has returned to his home town
Barb
438297
Reply By: Curlynan - Wednesday, Dec 08, 2010 at 23:14
I'm a bit of a coffee addict like your better half ;)
In cases like this I use our little 12v thermos to boil
water in and put a sachet of strong cappuccino into a mug and pour the boiling
water in. A bit of choc sprinkled on the top. Does the job. Alternatively, I use my plunger with a descent coffee in it and the
water from my 12v thermos.
Don't know where you get the thermos from as it was a gift but if your interested I could ask my frind.
438323
Reply By: Imanoone2u - Friday, Dec 10, 2010 at 07:27
Thanks folks, one of my greatest fear has come true.... We, the coffee snobs, must resort to manual coffee makers...(little tear in left eye).
Some valid comments & suggestions made here.
I've got one of these
Coffee makerl and it works quite
well. it's just......... not the same. (more tears).
Thanks for helping me in my quest though...
The obeyer
438440
Follow Up By: tdv - Friday, Dec 10, 2010 at 10:10
I have recently started using one of these. It makes both cappuchinno and latte.
Takes about 2 minutes and tastes pretty good.
Mukka Express
710186
