Instrument cluster removal 100 series
Submitted: Wednesday, Dec 08, 2010 at 18:41
ThreadID: 82941 Views:7787 Replies:1 FollowUps:5
I need to remove the instrument cluster from my year 2000 100 series to change some faulty globes. I have no idea where to start to remove it ? Is there a secret way of doing it, or hidden screws somewhere ?
I keep meaning to buy a gregorys workshop manual, but can't find any for the petrol 4.5
Reply By: Member - Graham H (QLD) - Wednesday, Dec 08, 2010 at 18:49
Well if they are the same as a 2005 TD
Pull black panel across top of steering column in front of instruments toward you and up
Four screws will be revealed undo the two Bottom ones in the white bits on each bottom side There are two in the top under the hood over the panel Feel with your fingers
Ease unit forward gently and remove attached cables All have only one place to go back so dont worry.
AnswerID: 438274
Follow Up By: eyspy - Wednesday, Dec 08, 2010 at 19:39
sounds good, I will give it a try on the weekend. Thank you
FollowupID: 709969
Follow Up By: Member - Graham H (QLD) - Sunday, Dec 19, 2010 at 10:12
Would be nice to lnow the result.
FollowupID: 711186
Follow Up By: eyspy - Sunday, Dec 19, 2010 at 13:10
Sorry, but I have 4 kids and planned things don't always get done when I want them to. Still have not done this task, will post up when I do.
FollowupID: 711213
Follow Up By: eyspy - Thursday, Dec 30, 2010 at 16:26
Well I finally got the time to do it and all went well. Thank you for your advice.....
FollowupID: 712101
Follow Up By: Member - Graham H (QLD) - Thursday, Dec 30, 2010 at 16:30
Very good
FollowupID: 712102
