speed and revs rodeo
Submitted: Sunday, Mar 10, 2002 at 01:00
ThreadID: 830 Views:2033 Replies:5 FollowUps:3
i was wondering if someone knows the most economical speed or revs for a turbo diesel rodeo
Reply By: brian - Tuesday, Mar 12, 2002 at 01:00
i have owned two rodeos and find that the most economical speed and revs are around 95 kmh at approx 2900 revs on highway work. i am getting approx 33 mpg consistantly although i have fitted an intercooler to my 2000 model d/cab
it does vary considerably off road
AnswerID: 2355
Follow Up By: Andrew - Tuesday, Mar 12, 2002 at 01:00
hey Brian, how did you find the vehicle after fitting the intercooler? worth it?
FollowupID: 846
Reply By: brian - Sunday, Mar 17, 2002 at 01:00
sorry luke made a blu 90-95 kph is about 2650 rpm and i find this about the most economical
AnswerID: 2410
hi andrew, the intercooler is fitted to a 2000 model dual cab and has boosted from 74kw to 92 and torque from 225nm to 265 as dyno tested by Bunbury Fuel Injection. it is mounted in front of radiator and is quite a large cooling area. power more noticable when loaded or towing. really happy with it. $1700 but worth it
AnswerID: 2411
Follow Up By: Andrew - Sunday, Mar 17, 2002 at 01:00
Thanx Brian, I have a tired '92 td rodeo, but want to update to a 99/00 model, and I tow a 16 ft van, so have seriously thought of the intercooler.
Sounds like the thing for my application.
FollowupID: 881
Reply By: Dion - Saturday, Mar 23, 2002 at 01:00
Luke, Brian & Andrew. I have a 2000 TD Rodeo, now with about 55000km on it. At the 20000 (6 months after purchase) I had a intercooler fitted by HiTech in Adelaide. The intercooler sits over the engine utilising a bonnet scoop. This puts power at about 96 kW, on par with the new 3.0L TD with intercooler.
I always drive at 110 km/h with cruise engaged, and consistently return about the 32/33 mpg, this speed is about 3050 RPM. I have not driven it consistently at higher speeds than 110 km/h, but would expect ecenomy to reduce.
The addition of intercooler does provide additional squirt for overtaking. Overtaking tripple trailer road trains is no problem.
Dion.
AnswerID: 2489
Reply By: Andew - Monday, Mar 25, 2002 at 01:00
Thanx guys, have any of you changed the exhaust system, to say a 2.5" mandrell bent system, theoretically there is more air volume going in, and coming out, ie, condensed cooler air at the intercooler over standard setup, ..
any comment?
AnswerID: 2504
Follow Up By: Brian - Thursday, Apr 11, 2002 at 00:00
hi andrew
no i havent changed the system but had previously thought about it. have you had experience with the mandrell system or similar
FollowupID: 1051
