Tyres BFG? Coopers? or Mickey Thompsons?
Submitted: Tuesday, Dec 14, 2010 at 11:47
ThreadID: 83057 Views:8650 Replies:19 FollowUps:9
Related Pages
Hi all,
I know its been asked before but I had pretty much decided on BFG, thinking that they are the best until recently I read some threads on Mickey Thompson tyres. I know there will be good and bad stories for all of these but is there any one of them that is a stand out? Will be doing the full lap with as much off road driving as possible in a 200 series crusier pulling a 20' van, just so you know what sort of usage they will get. All opinions appreciated.
Hado
Reply By: Mick O - Tuesday, Dec 14, 2010 at 12:47
Hado,
This is one of the most asked questions on the forum. Click on the article link at the top of your post. You’ll find over 5000 posts on BFGs, Coopers and Micky Thomsons. You can select each tyre brand individually. There is a post on Micky T’s just down the page a bit (Post 83019).
If you’re after the best (in my opinion) for rough work and off track work, Toyo Open Country MT’s. There are no substitutes in my book. Their sidewall construction is the strongest and most stake resistant I’ve come across yet.
Mick
AnswerID: 438868
Follow Up By: makintraks - Tuesday, Dec 14, 2010 at 12:58
Thanks Mick,
I have looked at the article but none of the options give me a Mickey Thompsons
link. Also when you open each one they are not specifically about tyres, they may mention something about a particular incident with a tyre at some point in the thread but just could not find any real good stories of experience. The other thread you mentioned has already got some good stuff on it, will keep following its progress, thanks for your help.
Hado
FollowupID: 710667
Reply By: Outback Bob - Tuesday, Dec 14, 2010 at 13:19
All good tyres.
I have used many brands and BFG's are the only tyre I have bought a second time and would buy again.
PS. Don't let the search police put you off asking as it's always good to hear up to date reports. If people stopped asking questions, new or old the forum would cease to exist.
Outback Bob
AnswerID: 438872
Follow Up By: makintraks - Wednesday, Dec 15, 2010 at 11:49
Thanks Bob, don't worry I intend to keep asking questions, the way I see it the search police don't have respond if they are sick of answering the same questions.
There is always new members joining and subjects like this are always of interest.
Hado
FollowupID: 710754
Reply By: Member - Mawso (WA) - Tuesday, Dec 14, 2010 at 13:29
We have done 80,000klms in 3 years on our first set of Mickey Ts 285/75/16 ATZ 5 ribs. Four laps of Tasi one lap of Oz, Strez track, Birdsville track, Old Telegraph track at the cape, The Great central Higway and up to Mitchel Falls in the Kimberly. No puntures, not a single tyre related problem and we have eight of them (camper trailer plus two spares).
Rotate them regularly and drop 10lbs out for gravel roads.
they will get a little noisey when they are getting old (in our case after 50,000klms).
Just put a new set on for the next 100,000klms and were pleasantly surprised at the cost.
Steve and Carol
AnswerID: 438873
Follow Up By: makintraks - Wednesday, Dec 15, 2010 at 11:51
Thanks guys, they sound good.
FollowupID: 710755
Reply By: Rod W - Tuesday, Dec 14, 2010 at 13:30
This is just another classic reason as to why the topics need to be categorised.
AnswerID: 438874
Reply By: Robin Miller - Tuesday, Dec 14, 2010 at 13:44
What type Hado ? - there are many answers to such an open question
usually most know there approximate size , and type of tyre.
e.g. Muddies , AT or an AT with LT construction
I look for the tyre that will get me their and back most saftely and choose its characteristics accordingly.
Hence BFG AT (LT construction) for me as they handle the most dangerous situations the best (loose dirt roads ).
AnswerID: 438875
Reply By: Member - Ray (QLD) - Tuesday, Dec 14, 2010 at 13:57
Horses for courses mate, I have a set of mtz's on the Nissan GQ, when travelling always up on weight, as above just drop a bit of preasure on the rough stuff, drive to the conditions and read the road, should be good.
Haven't used the others so can't comment on them.
AnswerID: 438876
Reply By: wato35 - Tuesday, Dec 14, 2010 at 14:01
When I travelled around the top end the tyre that seems to cause the most problems were Coopers. I saw a tyre that blew out, causing a fair bit of damage to the side of the vehicle. They had been travelling on the black stuff for some time when it happened. The tyre had plenty of tread on it, but Coopers where not going to stand by their warranty. I know there might be other factors that caused this to happen.
AnswerID: 438879
Reply By: Gone Bush (WA) - Tuesday, Dec 14, 2010 at 14:17
Hado,
I tow a 3500kg, 20ft, Bushtracker behind my 200 series.
I have fitted Hankook ATM (RF10) in 285/70X17.
Huge 1700kg Load Rating and the larger size cures the 4% speedo error in the OEM size tyres.
Fitted and balanced at my local dealer in town for $340 each.
They are very quiet and don't seem to wear very fast. I'm happy.
AnswerID: 438881
Follow Up By: drjfly - Tuesday, Dec 14, 2010 at 17:19
Same on my Triton (225/75x16). Just back from the Cape in Oct and not one tyre problem. Handled everything thrown at them and on top of them. Also recommend the Toyo's mentioned above. Use them on work vehicles for heavy loads, towing cross country.
Darren
FollowupID: 710686
Reply By: Wilko - Tuesday, Dec 14, 2010 at 17:00
Hi Hado,
Its horses for courses. If your after a set of tough as nails off road tyres buy the BFG's If you after tyres that are suitable for the black top only and should be trusted off road , get the others.
Flak jacket on, Helmet on, Head down, incoming artillery.
Cheers Wilko
AnswerID: 438890
Follow Up By: Gone Bush (WA) - Tuesday, Dec 14, 2010 at 18:19
if only that was true Wilko, instead of the opposite being the case.
FollowupID: 710690
Follow Up By: makintraks - Wednesday, Dec 15, 2010 at 11:55
Do I take it from this that you do not agree that the BFGs are tough?
FollowupID: 710756
Follow Up By: Gone Bush (WA) - Wednesday, Dec 15, 2010 at 13:29
The latest incarnation of BFGs seem to be gathering some negative views.
DYOR.
FollowupID: 710766
Reply By: StormyKnight - Tuesday, Dec 14, 2010 at 18:50
BFG MT's & now MT2's for my Prado - long life (100k) & I don't need to be concerned too much about the weather when I'm out!
Excellent in sand too...just go easy on wet hotmix mainly roundabouts when wet after being dry for a long time....
AnswerID: 438901
Reply By: Member - Joe F (WA) - Tuesday, Dec 14, 2010 at 18:51
G'day Hado
Simply put and from my personal experience.
Mickey Thompson MTZ = popular, long lasting BUT they have had carcase failures, with no product back up from the manufacturer or the on seller of the product.
BFG KM2 = popular, long lasting stable tread blocks, all these tyres are the Mud Terrain tread pattern.
I can not say anything about the Cooper brand of tyres apart from seeing more "Killed" Cooper tyres than the others.
I don't drive in the snowfields, or rain forrests or the sandy deserts of central Australia. I live in and drive throughout the Pilbara, all my tyres have sustained a puncture or two ~ thats life on and off road.
Good luck with your personal choice.
AnswerID: 438902
Follow Up By: makintraks - Wednesday, Dec 15, 2010 at 11:58
Thanks Jo, like I said i was swaying toward BFG muddies but then the Mickeys got thrown into the mix. Have heard too much bad stuff about Coopers so have struck then off the list.
Hado
FollowupID: 710757
Reply By: Member - Old Girl (QLD) - Tuesday, Dec 14, 2010 at 18:58
Just a little story
On one of our trips we went to a 4x4 park and took the "18" pop top. It was easy getting the van in but it poured most of our time there and I was a bit worried about getting out. It seems the blokes were too as I over herd a conversation about the plan to get out. I wasn't too impressed to say the least but we headed off. It surprised us all how the tyres dug in and got us out without any troubles at all. We are convinced it was the Micky T's atz. The same set have taken us to all sorts of places from Cape York to Adelaide via the Great Ocean Road, Vic High country and Blue Mountains over a 18 month period. Still going strong.
AnswerID: 438904
Reply By: AlbyNSW - Tuesday, Dec 14, 2010 at 19:21
Going by this and many similar threads I think you can easily it is the Holden V Ford style debate.
What doesn't get qualified enough with various opinions is the type of conditions that you are using a particular tyre in.
I am on my second set of MT MTZ's as I have been happy with them in all conditions, they have performed well for me in Cape York, Simpson desert and the Vic high country. For a muddie they also behave quite well on the black top as a daily driver.
I don't doubt that there are other tyres that will out perform them in a particular area but I think in general they tick all of the boxes well.
I did consider trying the BFG's second time round out of curiosity but thought I would stick with what I was already happy with.
BTW
I don't know why but the same size tyre, the BFG M2 is nearly 25mm narrower than the same size MTZ, I don't know why ????
AnswerID: 438906
Reply By: The other Norm C (WA) - Tuesday, Dec 14, 2010 at 22:52
Hi Hado
I run Cooper ST,s on my Ranger when on a trip,have
just done over 10,000 ks (GCR,Oodnadatta track Strezleky track
Cameron corner included ) a lot of dirt and corrugation's as well as tar
One puncher for the whole trip.I take them off when running around town
Norm
AnswerID: 438925
Reply By: Member - Don M- Wednesday, Dec 15, 2010 at 06:54
I have the MT ATZ 285/70-17 4 rib on my 200 and have done now 35,000km towing a 2800kg van around Oz, nearly home, currently in Bendigo.
My opinions ..., well they have performed well in all conditions, really good in sand, gravel and bitumen. Haven't done much mud. Dropped them to 25psi in gravel but still got a puncture on the Tom Price mine road. A sharp stone right through the tread on the front left.
Downside is that they are way too noisy for me and even more so for SWMBO. And, even though I have been rotating every 10000km, I doubt they will reach their 'guaranteed ' life of 80000km. They are over half worn out now and are even noisier than when new, sounds like all my wheel bearings are shot when on bitumen. (maybe they are!!).
I have never had either BFG or Cooper so can't compare but, based on this trip, I will be going for a much quieter tyre when these are worn. For the work I do, as long as it is AT tread and LT construction, then that will do. Now that Bridgestone do the 694 in 285/65-17, same size as OEM AND, now in LT, they will be the tyre I will probably go for. At the moment, it is the ONLY tyre that is LT and the same size as OEM.
The MT's are 833mm diam against the OEM at 809mm which strictly, makes them illegal and HUGE. The bloody truck is high enough anyway but it seems to look much higher with the MT's.
AnswerID: 438932
Reply By: Member - Duncs - Wednesday, Dec 15, 2010 at 18:56
Hado,
I have run BFG's and Coopers on my GU.
Over the years I ran 5 sets of BFG's, I loved them and could see no reason to change. Most people who run them are happy to keep buying them, and for good reason. They are a very good tyre.
I am currently running Cooper ST/C's. This is the third set on the GU and I got around 80,000km out of each of the first two sets and expect the same from this set.
The reason for the switch was simple. I was a happy BFG customer until the first set I put on the GU. I was concerned about the tyre wear so went in to see the local distributor. He set about accusing me of abusing the tyres, he got angry and was swearing at me and calling me all sorts of names that I will not repeat. And I had not asked him for anything. All I wanted to do was let him see the tyres so that he could give feedback to the manufacturer. Needless to say I walked out of the shop and started looking for tyres somewhere else.
I was reluctant to get the Cooper's but I had a professional relationship with the Cooper dealer and he convinced me to give the ST/C's a go. 170,000km's later and I am happy to keep fitting the ST/C's.
Tyre dealers are like doctors. Find a good one and cultivate a relationship. If he knows you will come back again he is more likely to think about what he recommends and not just sell you the tyre he makes the most money on. If Stubbsie from Bridgestone in Broken Hill recommends a tyre I will be happy to give it a go. Pity I now have to drive 1200km to see him.
I suspect any of the tyres you are looking at will provide good performance across a wide range of terrain. Similarly it is possible to get a bad batch and have problems with any of them. Once again that is when the relationship with the dealer pays dividends.
Duncs
AnswerID: 438979
Follow Up By: Member No 1- Thursday, Dec 16, 2010 at 08:36
up to 95000 with my coopers and still going...tyre dealer says maybe another 10K? its a work horse and carries tools and equipment in the back
FollowupID: 710850
Reply By: ross - Thursday, Dec 16, 2010 at 09:42
Ive had the Bridgestone D694 L/T for 18 months and are very happy with them especially in beach sand .
AnswerID: 439032
Reply By: Tonyfish#58 - Thursday, Dec 16, 2010 at 17:10
Original factory tyres on my RA Rodeo did 23k
A set of Cooper Sts did 31k
My Maxi Bravo 753s have done 36k and have another 10k in them
The Maxi Bravo are a better priced tyre then most, have been great Off and On road - They are worth a go
I am over Coopers tyres, they did chip on the rocks, the Maxis have not.
Cheers Tony
AnswerID: 439072
Reply By: Member - Graham H (QLD) - Friday, Dec 17, 2010 at 20:44
I put a new set of BFG's on my 100 to do a lap they have done 65,000k now and havent even had a puncture yet.
They are A/T's as I thought the muddies too noisy and not so good in the wet on tarmac.
Have found mine excellent, not noisy and gripped ok in offroad sand and the minor mud I got into.
Was towing a 2850kg van 75% of the time and they will still do a trip of Queensland later next year.
Would buy another set except will be selling the vehicle when trip finishes.
AnswerID: 439184
