installing after market auto aerial in 1999 landcruiser
Submitted: Saturday, Dec 18, 2010 at 00:46
ThreadID: 83124 Views:3941 Replies:5 FollowUps:0
having trouble with the wiring of my new aerilal . had a manual aerial when i brough the cruiser trying to install electric one need wiring diagram any help would be greatfull
regards
Harry
Reply By: Member - Marc Luther B (WA) - Saturday, Dec 18, 2010 at 02:08
Hi Harry
I am sure if you message Stuart from WA, he would be able able to help you. He is an auto sparky.
Why travel overseas, you could travel Australia your entire life, and not see it all.
AnswerID: 439204
Reply By: Member - Graham H (QLD) - Saturday, Dec 18, 2010 at 10:02
Try this If its a 100 there should be a connector in th L/H guard THere should also be a manual up and down control on the dash
Image Could Not Be Found
AnswerID: 439223
Reply By: Rangiephil - Saturday, Dec 18, 2010 at 11:16
Just remember there are 2 types of electric antenna.
Type 1 is switched by an up-down switch.(old fashioned now)
Type 2 is switched by the Radio when it is switched on.
This type AFAIR has a limiting switch so goes up to its height and stops, and then goes down in the absence of voltage from the radio.
Make sure you get the correct one for what you want to achieve.
Regards Philip A
AnswerID: 439230
Reply By: Member - Stuart P (WA) - Saturday, Dec 18, 2010 at 18:39
what colours are the wiring? message me with a contact no and i will help you work it out
AnswerID: 439264
Reply By: Member - reggy 2 (VIC) - Monday, Dec 20, 2010 at 17:09
When I done mine I just put a two way spring loaded switch on the dash .
Up for up down for down at least that way you can control it in the bush
MERRY XMAS
AnswerID: 439416
