electric brakes on trailer setup
Submitted: Sunday, Dec 19, 2010 at 13:31
Samuls35
hi with the electrics brake how is the wiring from the hubs to the car done got 2 green wires out of each hud. i think i know what im doing just double checking
thanks again
Reply By: Roughasguts - Sunday, Dec 19, 2010 at 14:12
Sure there not blue wires ?
Don't wan't to conect your brakes to the left indicator light.
439333
Reply By: Member -Dodger - Sunday, Dec 19, 2010 at 15:08
From each electric brake magnet you should have 2 wires one is earth and the other goes to the vehicles brake controller.
It does not matter which wire igoes to the controller as long as the other is to earth back through the vehicle through the elec coupling.
Most brakes have a common earth return and a common power wire from the controller. AS per the Australian standard wiring for vehicles.
439336
Reply By: Member - Graham H (QLD) - Sunday, Dec 19, 2010 at 15:13
2 should go to pin 5 on your connector and two to the earth wire.
439337
Reply By: Roughasguts - Sunday, Dec 19, 2010 at 16:27
You have got a brake controller haven't you ? Haines / prodigy Etc
439341
Follow Up By: Samuls35 - Sunday, Dec 19, 2010 at 18:42
i dont know whether or not to take that as a insult ......
711242
Follow Up By: Member - Graham H (QLD) - Sunday, Dec 19, 2010 at 19:32
I think in view of your original post its a fair question.
When safety is a consideration there is no half measures
711249
Follow Up By: Roughasguts - Monday, Dec 20, 2010 at 17:12
No mate not insulting anyone, sorry if I offended.
Cheers.
711324
Follow Up By: Begaboy - Wednesday, Dec 22, 2010 at 12:48
It was a fair question , a few weeks ago there was a question raised about brakes(on a trailer ) and not needing a brake controller as the OP hooked directly to the brake light loom - sometimes when offering advise you need to know the basics have been followed before continuing with the more complicated solutions
711464
Reply By: Dunaruna - Monday, Dec 20, 2010 at 17:28
Both of the magnet wires are green.
One wire goes to pin 3 (earth).
The other wire goes to pin 5 (service brakes)
Doesn't matter which one goes where, the magnet will work either way.
Join the two magnet wires between the
wheels on the axle, dead centre.
439419
