Monday, Dec 20, 2010 at 19:12
Try the following steps carefully and in the correct order ..
Disconnect from battery .
Lay the panels face down ( No light on them at all ! )
Connect the reg to the battery terminals as normal .
Count to 30 ..
Now lift up the panels and aim at the Sun ..
If that doesn't fix your problem then the reg is kaput !! ..
A lot of regs NEED to sense the battery charge voltage before Solar input ..
I used to sell an MPPT controller that did exactly what you have described and the above is the ONLY fix ..
Steve
711334
