Surface rust???
Submitted: Tuesday, Dec 21, 2010 at 00:15
This Thread has been Locked
Liveit
After alot of care and effort in covering and protecting the back end of our van whilst my husband grind off the old bumper and re made with
fuel carriers, and the bike carrier i have now noticed a tinee tiny bit of surface rust above the number plate light and on the covers around the brake lights. These are both plastic but are on the edge near the alliminium/metal... Its clearly from the grinding dust that must have snuck through the gaps somehow.
Does anyone no how to remove it??? And will it get worse??
Its a Coromal lifestyle 610.
Reply By: Dunaruna - Tuesday, Dec 21, 2010 at 07:26
It is possible that the rust is from the screws that retain the covers, they do not use SS screws. can you post a pic?
The coromal has alluminium sheeting, no metal. Allum.. will not produce rust stains.
439462
Follow Up By: Liveit - Tuesday, Dec 21, 2010 at 13:13
As stated in my post ALUMMUINIUM and in "BRACKETS" i wrote METAL..
It is metal fragments from the grinding which has settled on the ALLUMINIUM.
YES there is rust and no its not from the screws it is from grinding as suggested in the post.
711374
Reply By: pepper2 - Tuesday, Dec 21, 2010 at 09:21
it may be steel fragments from the grinding of the old bumper that would have been made from steel,remove with
water blast or soap and
water wash.they will continue to rust if not removed and may stain the vans surface.
439474
Follow Up By: Liveit - Tuesday, Dec 21, 2010 at 13:11
Yes it is steel fragments..
Thanks for your reply pepper2 ill get right onto it before it gets worse or stains. Thankyou.
711373
Reply By: Member - Graham H (QLD) - Tuesday, Dec 21, 2010 at 09:21
I would be more worried about how adding all this extra weight to the rear of your van will alter its load dynamics and handling than a bit of surface rust.
When grinding it pays to either vacuum all the dust or blow it off with an air hose
All vans have a Legal ATM and an allowable payload which is pretty hard to stick to without adding
fuel and bikes to the rear.
This will lighten your ballweight and a tail heavy van is certainly not a safe van.
Also carrying
fuel , especially petrol on the rear of a van is rather dangerous.
Lots do it I know but on the A frame is safer.
Coromal also recommend that extra weight not be added to bumper bars due to the extra weight adding to chassis flex..
With my 754 I could not do that anyway as it would exceed
the overhang legally allowed. I had to bolt my spare carrier on to be able to say it was temporary.
Adding about 80kg to the bumper has to come out of your payload and when you hit a big bump will be multipied several times putting more strain on the chassis.
A lot more to it than just doing it and not thinking about the consequences.
439475
Follow Up By: Liveit - Tuesday, Dec 21, 2010 at 13:10
Well before you go jumping to conclusinos AGAIN. We have checked all this out. Your the same person who jumped at your chance to blast me for having a tool box on our A frame... You like rain'ing on peoples parade dont you.
Once again go around dripping Crap that has nothing to do with my question.
711372
Follow Up By: Madfisher - Tuesday, Dec 21, 2010 at 13:31
Bit senisitive arent we.
Cheers Pete
711375
Follow Up By: Member - Graham H (QLD) - Tuesday, Dec 21, 2010 at 14:18
Pehaps I am a bit more safety conscious and try to stay legal
You do what you like, its your van, your money, your life.
I really dont care what you do just try to offer some sensibility in these things.
After seeing vans that are obviously overweight
I wonder what some people are thinking or perhaps not thinking at all.
And Coromal do advise against adding things on the rear towbar.
My dealer wouldnt take responsibility for the spare tyre I put on when I bought the van.
I wasnt Blasting anyone was just offering sensible advice which you obviously dont appreciate so go your own way.
711388
Reply By: Member - Tour Boy ( Bundy QLD) - Tuesday, Dec 21, 2010 at 13:43
Once you have thoroughly washed and dried it, give it a good coat of polish like carnuba wax (would be good to do the whole van and car too) to prevent the rust from staining. Carnuba cleaner wax will get rid of oxidisation (paint fade) and stains if it has got too bad.
439496
Reply By: gbc - Tuesday, Dec 21, 2010 at 13:55
A dose of penetrol will seal it up and prevent rust unless it's chipped off like any other paint.
439502
Reply By: cycadcenter - Tuesday, Dec 21, 2010 at 14:38
Guess we lost the other thread..............
It was entertaining while it lasted'
Bruce
439507
