How do I replace the handbrake cable on a camper trailer?
Submitted: Tuesday, Dec 21, 2010 at 16:50
ThreadID: 83175 Views:9977 Replies:2 FollowUps:1
As many of you are aware I have had a big problem with brakes I had installed on the camper trailer a few months ago.
I have now got a bit of time at home and have started to fix the damage.
First job was to get the 'U' bolt nuts tightened and the flat plate between the axle and spring mounts welded back into place. This was done this morning.
Second job was to replace the handbrake cable. This is in progress, but I'm not sure about the adjustment procedure, ie how tight do I need the cable to be when I first put it on and what position should the handle be in when this is done.
Then I need to know the fine tuning and what notch the handle should be in when I pull the handbrake on.
The hand brake I think is a VC type. It is welded onto the A frame near the coupling and has a red button that you depress to release the brakes.
The last three jobs will be rewiring the electric brakes and checking the bearings and brake linings before I sell it.
Any help regarding the handbrake adjustment would be appreciated.
Reply By: Member - Boo Boo (NSW) - Tuesday, Dec 21, 2010 at 17:42
Sorry,,, a seniors moment ,, its an al ko handbrake with a red handle and a silver button ,, not a red button.
AnswerID: 439528
Reply By: Member - Matt L (WA) - Tuesday, Dec 21, 2010 at 18:59
You are in trouble by the looks of things, first put the cable into the hole on one actuating lever and clamp it tight with a rope clamp, second put the cable through the front loop then bring it back to the second actuating lever but make sure the hand brake is fully in the down position and the thread on the adjusting bolt is screwed right back ,only leave enough thread on the bolt so it doesn't fall off, then thread the cable through the second lever pull it by hand till it come's through without the actuating arms moving , then clamp it with the second rope clamp. The adjustment is done at this point by the bolt you screwed right back ,screw it forward till you have 3 or 4 notchs before the hand lever gets tight. But you must do your wheel bearings and brake adjustment first or you are wasting your time.
AnswerID: 439534
Follow Up By: Member - Boo Boo (NSW) - Tuesday, Dec 21, 2010 at 19:46
Matt,
I did actually get the cable and rope clamps in place, but I do appreciate the info you have given me.
I will now complete the job tomorrow and then get the wiring done.
Thanks Matt, have a great Christmas and a healthy New Year.
FollowupID: 711412
