help needed with new battery
Submitted: Monday, Dec 27, 2010 at 12:10
Member - John & Sally W (NSW)
Hi everyone,
We were wondering if someone might have better knowledge than us on this problem. We purchased a new 75amph battery for our caravan on Thursday. Attached polarity correctly but can't seem to get % above 69% on regulator plugged into 240 volts. Do we have to reset regulator again. I have reread through the instruction booklet a number of times but it doesn't mention anything about resetting the regulator after changing the battery. The van is under a carport and so solar panel is in no charge mode which we can understand but we thought that after nearly 4 days of charging by 240v it would be 100%. Until our old battery died it topped up to 100% after use all the time. Any input would be grateful.
Sally
Reply By: Notso - Monday, Dec 27, 2010 at 12:26
what size charger have you got?
439900
Follow Up By: Member - John & Sally W (NSW) - Monday, Dec 27, 2010 at 13:23
Oh! I don't know as it is installed into van, but battery was replaced with exactly what we had.
711782
Follow Up By: Notso - Monday, Dec 27, 2010 at 13:33
You might try resetting the regulator although I don't know what effect it would have.
Have you got the equipment to check the voltage at the battery terminals? If it's in float mode the voltage should be about 13.8.
Otherwise get an auto electrician to check it out.
711784
Follow Up By: Member - John & Sally W (NSW) - Monday, Dec 27, 2010 at 14:23
Thanks Notso,
I checked and the voltage is 13.7
Might ring auto guy Wed when he returns from work to just check things are good.
Thanks for your help,
Sally
711789
Reply By: Mandrake's Solar Power- Monday, Dec 27, 2010 at 18:27
It looks like the reg is set for a 105/110 aH battery .. was that the size of the previous one ? 69% of 105 or 110 = 72.5 to 75.6 ..
Might need to reset or change the battery size in menu land ..
Steve
439939
Follow Up By: Member - John & Sally W (NSW) - Monday, Dec 27, 2010 at 20:32
Hi Steve,
Thanks for that info. Will check it out in the morning.
Sally
711825
