Wind Generator - Jaycar Electronics
Submitted: Tuesday, Dec 28, 2010 at 09:00
ThreadID: 83289 Views:19744 Replies:11 FollowUps:17
Has anyone had any success with these smaller 50 watt wind generators available form Jaycar Electronics? Thinking of getting one to compliment solar panel and Honda generator.
http://www.jaycar.com.au/productView.asp?ID=MG4570&keywords=wind+generator&form=KEYWORD
Telescopic Vertical Axis Wind Generator 50W
One of the disadvantages of conventional wind generators is that they occupy a lot of space with spinning blades and large poles. A vertical axis generator addresses this by taking up much less real estate, so can be mounted on a boat, mobile home, caravan or small building. Another advantage is that they are more suitable for areas where the wind direction is variable, as they don't need to be pointed in the wind direction to be effective. The telescopic design means you can fold the generator to half its length when not in use or for high wind speeds, and an LED display give you a readout of output voltage so you know when it's working effectively. Cables, mounting bars and a strong magnetic base are included so this is a complete portable wind generator solution for boating, 4WD, camping, fishing etc.
• Compact design with no spinning blades
• No mounting hardware required
• Not sensitive to wind direction
• Effective with wind speed of 8 - 10m/s
• Includes 2m cables with alligator clips
Specifications:
• Voltage output: 12 - 16VDC
• Current output: 4A max
• Weight: 4.5kg
• Dimensions: 455/655(H) x 280(W) x 150(D)mm
QTY
1+ $399.00
2+ $359.00
4+ $319.00
Reply By: Member - Porl - Tuesday, Dec 28, 2010 at 09:48
Let's get a buying group of 4, members only for security, and buy 4. I'm in. Just got back from Woodford, no sun because it was rainy - and windy. That unit I see I could have been mounted on a block of wood and strapped to my roof racks while I was bogged beside my tent for 3 days. Oddly, as I was swearing I needed MT's, I heard someone else swearing and 20m away was a hilux with Mickey Thompson MT's, 34's by the look, bogged down to his axles outside his tent, he's still there. A bag of rocks and deflated tyres got me out, but I was a lot closer to the road than him. He wasn't around for me to offer a strap when I finally got out and left.
AnswerID: 439999
Reply By: rooster350 - Tuesday, Dec 28, 2010 at 10:20
Saw one in action when in W.A. earlier in the year , it was on a small motor home...the chap gave us (and others) a run down on it...quite impressive...completely silent operation , he was using it mainly to run a CPAP machine...he reckoned it was the ducks guts and I was not going to argue.....cheers
AnswerID: 440002
Reply By: Member - Andrew (QLD) - Tuesday, Dec 28, 2010 at 10:36
It would be interesting to see how they go. Though they are listed as effective with 15-20 knot winds (28-36 km/hr)!, i'm not sure how useful it would be. At least with solar etc, there is a better chance of receiving adequate conditions to operate. :)
I would be interested to see if a regulator is available/required for the output.
Andrew
AnswerID: 440004
Reply By: KenInPerth - Tuesday, Dec 28, 2010 at 10:47
Hi Adey
Offering my thoughts (which based on another thread some think are worthless) I would put forward the following to maybe spark some more informed or experienced opinion. In my view the best information comes from those that have actaully used and made something work - not theory.
1. Efective with wind speed of 8-10 m/s - this is roughly 16 - 20 knots of wind which is a fair bit of breeze required for it to be "effective" - by which I assume means it will start to output useful power at that wind speed.http://www.unitjuggler.com/speed-conversion.html
2. I would expect you need a charge regulator between it and the batteries as you do for solar cells, and would it's output voltage be high enough most of the time to be able to use it as a battery charger ??
3. Questions in my mind - does it output 0 Volts until it reahes "effective" operation and then "switch on" the output ?? Does the voltage vary according to wind speed, or does it supply 16V at low current draw and 12V at high current draw regardless of wind speed?? in which case it may be suitable for charging batteries (via a suitable regulator)
Hopefully someone has had some practical experience and can add more helpful information to this for you, or you may want to ask Jaycar to provide more detailed specifications as those specs are pretty "scant" in terms of actual operating conditions and performance.
Ken
AnswerID: 440006
Follow Up By: Member - bungarra (WA) - Tuesday, Dec 28, 2010 at 14:22
Ken
good informed questions...the answers will be interesting........I have occassionaly given a wind turbine some thought
I have been totally solar for years and learnt the hard way.....under performing gear and power hungry devices etc.......bad battery choice ....under size cables.....(the local auto sparky !)......etc.........been there done it all (a very steep learning curve) very few sales persons went camping or understood the basic principles..........( still a lot of poor advice and lack of understanding out there.....and still a lot of people get bad systems and advice! )
I learnt by trial & error...making / purchasing some test gear.....and reading widely.......and then over time have what is ideal for us.........
dont take to heart of some of your previous threads responses..........at the end of the day.......all input and difference of opinions from a wide ranging source does eventually contribute something positive.........(sometimes)
VKS 1341
FollowupID: 711869
Follow Up By: Adey - Wednesday, Dec 29, 2010 at 08:55
Thanks Ken. Answers thus far:
1. Correct and agreed. Winds of 16-20 knots will be required which is not a huge concern for me as we camp by surf beach and there is often winds of that strength especially when there is little or no sun.
2. Jaycar sales rep advises that there is a regulator included in the unit.
3. Not to sure on this one but I think it operates at circa 14.5 charge but only when up to speed on the wind front.
As stated this is merely to compliment my solar panel and generator which can not be used all the time.
It appears as always there is conflicting advice but more 'nays' than 'yays' so I may wait a little longer to see what other reviews reveal.
FollowupID: 711933
Follow Up By: KenInPerth - Wednesday, Dec 29, 2010 at 10:51
Adey
Lots of replies I see. I think the answer on this one lies in someone actually using it for the same purpose as yourself and how they did it. Experimenting with this one could be costly in may ways.
My only reservation from what you have found would be the purpose and "smartness" of the regulator. Solar regulators as far as I know have some "smarts" in them to control battery charging (primarily to prevent overcooking the battery). Not sure this unit would have that smart a regulator in it.
But at the same time as a top up for the batteries it could still work - at least it would bring the batteries back up to some higher level of charge as long as it's output was higher than the battery voltage.
More questions though - is it protected from reverse current (ie when battery voltage is higher than the output of the generator) if connected directly to batteries?? Given the dynamics of charging batteries these days, if it can and does push 4Amp into your batteries (at any voltage) will this be harmful to your specific batteries??
Out of curiosity I might drop into Jaycar and see what I can find out for future reference.
Being the ultimate sceptic, I am very wary of what most "sales people" tell you these days because if they cannot read it off the box the product comes in they have no idea. I guess this is a legacy of stores selling a wide range of products some of which do need specialist knowledge.
As Bungarra said, very few people trying to sell you something have actually used the product at all let alone in the specific application you are trying to use it for.
We all learn a lot by making some "not so good" decisions at times, even after trying to research something well, but sometimes there is no other way than to try it and see, unless you really do get lucky and find someone that actually knows and / or has used the product for what you are trying to do. It makes it costly though on expensive items like this to "try it and see" if it doesn't work, although according to Consumer Affairs you do have come back if it does not do the job you are told, or it claims, it will do. For this reason most (not all) manufacturers will list some applications on the box.
The really disappointing thing to me (as Bungarra also stated) is when you get bad advice from someone that should know (like his local auto sparky). We see this all the time in our industry from both the "box movers" and "professionals that should know better". Not to say we are perfect - no one is - but we support everything we do so we need to get it right or we will forever be fixing up our own mistakes at our cost. I think that makes a big difference to the advice you get.
FollowupID: 711947
Follow Up By: Adey - Wednesday, Dec 29, 2010 at 10:57
Thanks again Ken - I don't disagree with your thoughts. The reason I am an avid user of exploroz and frequent the advertises products is essentially because of people like you and others that take the time to respond to questions posed by people they don't know.
Cheers and have a great 2011. I am off now to the far north NSW coast for a couple of weeks in the pouring rain!!!!!
FollowupID: 711948
Follow Up By: KenInPerth - Sunday, Jan 02, 2011 at 20:55
Hi all
I went and had a look at one at Jaycar and asked a lot of these questions which I have subsequently put in an email to the Store Manager who will supposedly get me the answers.
What I do no further to the previous thread is that in the manual that comes with it they show a picture of it connected to a battery as one of the uses. The guy I talked to said they tried one out at the beach (with no load though) and it "seemed to output 13.8 Volt" - but I stress this was no load.
The store guy's comment was " I prefer solar because if a regulator blows up it is not super expensive but if this wind generator dies it is basically throw away". But that is a cost based coment and not a performance or usefulness based comment
Apparently it does output all the time (not just when it gets up to efective speed) and hence the reason for needing reverse current protection which is one of the questions.
I still don't know answers to some questions and will post them if I get them.
Ken
FollowupID: 712417
Reply By: crfan - Tuesday, Dec 28, 2010 at 12:00
This post has been read by the moderation team and has been moderated due to a breach of The Advertising/Self-Promotion Rule .
Forum Moderation Team
AnswerID: 440011
Reply By: roberttbruce - Tuesday, Dec 28, 2010 at 13:49
surely they must be noisy...
AnswerID: 440015
Follow Up By: Adey - Tuesday, Dec 28, 2010 at 14:56
Apparently not from advice received thus far.
FollowupID: 711873
Follow Up By: roberttbruce - Tuesday, Dec 28, 2010 at 17:57
i suppose it would be possible to keep the whirring of the windings down to the level of the wind noise....is maybe why they are low amps
FollowupID: 711884
Follow Up By: rooster350 - Tuesday, Dec 28, 2010 at 20:30
I was standing 3 feet from the one I saw in W.A. and I could not hear any sound coming from it...I have already stated that it was silent , how silent do you want ?
FollowupID: 711902
Reply By: lizard - Tuesday, Dec 28, 2010 at 14:14
A smart bloke had one of these up North - 3 yrs ago - he was disappointed with its performance .... got more out of his solar for the same money .
AnswerID: 440017
Follow Up By: Adey - Tuesday, Dec 28, 2010 at 14:57
Thanks Lizard. I already have solar panel but just trying to cover the bases when it isn't sunny. Also have generator but have to be mindful of other campers when I run this and also unable to run generator in NSW National Parks.
FollowupID: 711874
Reply By: Member - John - Tuesday, Dec 28, 2010 at 15:57
Adey, Think the idea has merit, if you are stuck some where for a few days, rain cloud etc, hopefully it would be windy, put it up and bingo, power.................
John and Jan
AnswerID: 440026
Follow Up By: Member - Redbakk (WA) - Wednesday, Dec 29, 2010 at 13:32
Adey...I agree with John here, as they are used by the sailing fraternity in their various forms and quite successfully as well......as I have 2 x 160 solar panels you can see that 50 watts would not do a lot for my set up BUT in saying that, I have thought about wind generators as a addition to what I already have ( or I suppose that you could just spend the money on beer instead....but whatever rocks your boat)
Sometimes I think it would be good to have a product review section on this forum that we all could refer to, ie wind generators, solar panels,winches etc etc on which we all could contribute for the benefit of others....but that idea may be fraught with trouble. :))
FollowupID: 711965
Reply By: Simon C - Tuesday, Dec 28, 2010 at 17:02
Have a look at www.hobohome.com
They have are article on a Jaycar wind generator that is fairly comprehensive. Advice from people who have actually been there and done it.
Simon C
AnswerID: 440029
Follow Up By: Adey - Wednesday, Dec 29, 2010 at 08:57
Thanks Simon - Hobohome very informative site and I have bookmarked it accordingly. The story on the wind turbine whilst of value does not relate to the exact item I am looking at. Thanks for responding though - really appreciated.
FollowupID: 711934
Reply By: garrycol - Tuesday, Dec 28, 2010 at 17:31
A friend has one on his garage roof. Says it is a waste of space as it only generates anything decent in very strong winds - anything less and the amount of energy generated is not worth consideration.
AnswerID: 440030
Follow Up By: V8 Troopie - Wednesday, Dec 29, 2010 at 01:08
I would wholly agree with that, it an overpriced toy. Lots of 'feelgood' factor but no economical advantage.
I have been tinkering with wind generators for a few years, vertical axis ones and my experience is that even a 5 times bigger unit does not come close to the output of a 1m diameter horizontal axisunit in comparable winds.
Save your money for more solar panels - much better investment.
FollowupID: 711918
Follow Up By: Adey - Wednesday, Dec 29, 2010 at 08:59
Thanks for responses. Still looking at this as an option and as reported above - this wind generator is merely to compliment my solar panel and generator when unable to use. Looks as though there are more people advising that power will not be sufficient so I may wait and see after undertaking more research.
FollowupID: 711936
Follow Up By: Ianw - Wednesday, Dec 29, 2010 at 21:24
You have to look at how much time you spend in areas with 28-36 kph winds !
Anything less than that and it wont charge your battery at all. I personally look for sheltered areas when I camp.
Ian
FollowupID: 712007
Reply By: paulnsw - Wednesday, Dec 29, 2010 at 21:50
Checked these out and read and digested the specifications. To get any meaningful output you would need high constant winds. If you check out the wind rose on BOM website you may be surprised how little wind many parts of Australia get. Some locations are only good in mid winter. Considering you can buy Suntech 85W solar panel for $400 I know where I would spend my dollars. On a poor weather day you would get more from an 85W panel compared to that wind generator.
AnswerID: 440144
