extended shackles
Submitted: Tuesday, Dec 28, 2010 at 17:24
Member - Matt K (NSW)
Hi, I'am considering buying extended shackles for the 75 cruiser wich has a 2'' lift.Can i bolt them straight on or do i need new shocks. Any info would be great.
Reply By: Patrol22 - Tuesday, Dec 28, 2010 at 18:00
G'day Matt K
You will probably need longer shocks but before you go down this path you should check with the RTA but probably more importantly your insurance company as I believe that longer than factory fit shackles are not legal in NSW....with or without and engineering certificate. You will get an initial idea from
THIS RTA DOCUMENT - see page 4 but best to check directly with those who make the decisions.
440033
Reply By: Member - Graham H (QLD) - Tuesday, Dec 28, 2010 at 19:26
I believe they are illegal everywhere except maybe the NT
440046
Reply By: Mick O - Tuesday, Dec 28, 2010 at 20:40
Hi Matt,
Can’t speak as to the legality but I know my insurance has covered both the shackles and the
suspension mods and they are listed on my policy.
I’ve found them to be a boon in gaining that extra height I needed under the tray. You will need extended shocks and I would also suggest ensuring that your leaf springs are suitable. They may need an extra leaf or two fitted. Because of the weight I carry at times, I’ve also added a set of firestone bellow type airbags to assist load carrying. I’m using the Snake Racing shackles.
Cheers Mick
440052
Reply By: Ozhumvee - Tuesday, Dec 28, 2010 at 22:06
Extended shackles are illegal for on road use in all states except the NT as far as I know.
440056
Reply By: Member - Phil G (SA) - Wednesday, Dec 29, 2010 at 18:36
First, you'll find the 78/79series shackles are 23mm longer than the 75series if you want an option thats not too aggressive, and theres a chance you'll pick up a set for nothing. I don't know whether the 78/79series rear shackles will fit the 75series fronts as
well, but can't see why not.
The aftermarket shocks for 2" lift are extend about 40mm longer than standard. If you fit shocks that are any longer than this, you'll need to extend the brake lines.
440115
Reply By: Member - Alastair D (NSW) - Friday, Dec 31, 2010 at 11:15
Matt,
Make sure you adjust the rear brake compensator now you have a lift and possibly longer shackles. It will help to regain a bit of braking especially when the load is light. The unit is on the drivers side just above the rear axle. Mode of adjustment is covered on the LCOOL website. If you want an outline then send me a MM.
440284
